RV.Net Open Roads Forum: Find cross pieces under metal roof to mount solar panel?
 > Find cross pieces under metal roof to mount solar panel?
joerg68
St. Ingbert, Germany
Posted: 03/16/21 02:02am Link  |  Quote  |  Print  |  Notify Moderator
On my 2002 Lance, the aluminum sheet roof was loose on top of a layer of plywood, with a thin layer of foam in between. It was not glued down as far as I could tell. That would exclude the no-screws method.
The roof on that camper could be walked on, so I would assume there was a decent layer of plywood (1/4" ?) everywhere. I know there is on my current Northstar camper.
Bert the Welder
Van. Island
Posted: 03/17/21 01:29am Link  |  Quote  |  Print  |  Notify Moderator
Yep! That would be a problem.
Though, it may not be if there is little lift on the panels. Hell there might even be downward pressure, making them stick better! [emoticon]
"> 1998 GMC 2500, 10.5 Okanagan, My better/smarter half, George and Finnegan(APBT), all I need.
Geewizard
WA
Posted: 03/17/21 06:23am Link  |  Quote  |  Print  |  Notify Moderator
bighatnohorse wrote:
In the event that you cannot find metal substructure I would submit for your consideration using well nuts.
They are inexpensive and you can fail-test them in your garage/work shop by installing them in 1/8-inch luan and attempting to pull them out.
They work.
I tried well nuts and they failed to hold my solar brackets to the degree I wanted.
I chose to use rivnuts (threadserts is another name) and specifically this rivnut kit.
Mine were inserted through the rubber roofing and luan into the hole I drilled in the roof's aluminum tubing. This has worked well for about 15 years.
2004 Outfitter Apex 8
2014 Toyota Tundra Double Cab
300W solar, MPPT controller, LED lights
2 Fullriver 100AH AGM batteries
Compressor fridge
Wave 3 Heater
Air Lift WirelessAIR and air bags
Hankook Dynapro ATM 10-ply tires
