RV.Net Open Roads Forum: Fifth-Wheels: Tire life
 > Tire life
b_pilot
Posted: 03/13/21 10:07am Link  |  Quote  |  Print  |  Notify Moderator
I have a fifth wheel with Goodyear G614 G rated tires. They still have very good tread and still look good but they were made in the 19th week of 2014. I read that you can go between 6 to ten years. I know there will be many different opinions on this but I would like to hear some. Thanks.
Near DVNP, California
Posted: 03/13/21 10:25am Link  |  Quote  |  Print  |  Notify Moderator
Six to ten years is too long for my peace of mind. I go four to five. Looking good isn’t the deciding factor. Even according to what you’ve read, it’s time.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, 300 watt solar-Lossigy 200 AMP Lithium battery. TALL flag pole. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
MFL
Midwest
Posted: 03/13/21 11:45am Link  |  Quote  |  Print  |  Notify Moderator
Just like all tires not being equal, so is the care that the tires receive. If a quality tire, such as yours, is well cared for a 6-10 yr life IMO is accurate. With fair amount of care 6 years, and excellent care closer to 10 yrs. Tire life can vary due to inflation practices, storage surfaces when not in use, parked in sun, parked/standing long term, hitting curbs and potholes, overloading, or too high of speed.
You know more how they have been treated, than anyone here. If you feel they've had excellent care, I'd trust them another year or two.
Jerry
2oldman
NM
Posted: 03/13/21 01:23pm Link  |  Quote  |  Print  |  Notify Moderator
Depends on what they look like, but, for real good peace of mind I'd get a TPMS.
jdc1
Rescue, Ca
Posted: 03/13/21 01:57pm Link  |  Quote  |  Print  |  Notify Moderator
Jerry
I agree. Check the valve stems for cracking to. I overlooked quite often.
wildtoad
Blythewood, SC
Posted: 03/13/21 02:08pm Link  |  Quote  |  Print  |  Notify Moderator
If you’ve kept them clean, proper pressure, used the unit fairly frequently they may good for a while longer. If it’s used once or twice every now and then and sitting for long periods of time, get them professionally inspected. The the worst thing you can do to any RV/Tire is to let it just sit.
Tom Wilds
Blythewood, SC
2015 Jeep Wrangler 2dr HT
philh
Belleville MI
Posted: 03/13/21 03:21pm Link  |  Quote  |  Print  |  Notify Moderator
6 years MAX
MarkTwain
Northern, Ca. , USA
Posted: 03/13/21 05:12pm Link  |  Quote  |  Print  |  Notify Moderator
A lot depends on how much of a risktaker you are and if you have a good Roadside Emergency Service. Another variable is what kind of RV trips you take and how often. Long trips .ie 1K to 5K 2 or more times a year. Short trips 500 miles or less. Are you ok dealing with possible damages to your RV from a blowout? As they say, "roll the dice and take your chances" I used the G614 Good Year tires for years and used to get new tires about every 5 to 6 yrs.
* This post was edited 03/14/21 09:01am by MarkTwain *
Michelle.S
Western NY till fall, then Sebring, FL
Posted: 03/13/21 06:02pm Link  |  Quote  |  Print  |  Notify Moderator
I was running the GY 17.5" G114s and was hoping for 5 years, but one let loose at 4 1/2 years. Always run at correct pressure with the TST 507 TPMS and every thing was normal till BANG and rubber flying every where. Now running Sailun tires.
2018 Chevy 3500HD High Country Crew Cab DRW, D/A, 2016 Redwood 39MB, Dual AC, Fireplace, Sleep #Bed, Auto Sat Dish, Stack Washer/Dryer, Auto Level Sys, Disk Brakes, Onan Gen, 17.5" "H" tires, MORryde Pin & IS, Comfort Ride, Dual Awnings, Full Body Paint
pcm1959
home
Posted: 03/13/21 06:48pm Link  |  Quote  |  Print  |  Notify Moderator
I replaced my 17.5 GY G114's last May that were produced late 2014 strictly due to age. They had about 22k miles on them and looked like new. I just didn't want to chance it based on the "age-out" theories.
2018 GMC Sierra 3500 DRW 4x4 Duramax/Allison
2014 Lifestyle LS36FW
St Augustine, FL
 > Tire life
