RV.Net Open Roads Forum: Fifth-Wheels: Tire life
 > Tire life
BB_TX
McKinney, Texas
Posted: 03/13/21 06:57pm Link  |  Quote  |  Print  |  Notify Moderator
Don’t know about Goodyear. Here is what Michelin says;
“A few milestones and tips:
Keep five years in mind
After five years or more in use, your tires should be thoroughly inspected at least once per year by a professional.
Ten years is a maximum
If the tires haven't been replaced 10 years after their date of manufacture, as a precaution, Michelin recommends replacing them with new tires. Even if they appear to be in usable condition and have not worn down to the tread wear indicator. This applies to spare tires as well.”
https://www.michelinman.com/howLongTireLast.html
I replaced mine at 9 years and still looked virtually new.
time2roll
Posted: 03/13/21 07:53pm Link  |  Quote  |  Print  |  Notify Moderator
b_pilot wrote:
I have a fifth wheel with Goodyear G614 G rated tires. They still have very good tread and still look good but they were made in the 19th week of 2014. I read that you can go between 6 to ten years. I know there will be many different opinions on this but I would like to hear some. Thanks.
I agree with 6 to 10 on those tires. Then it is just probability if it should fail. Not that 6 years is zero probability and 11th year is 100% failure. Could last 20+ years for all we know. I bought a used car once with two of the the original 30 year old tires and still drove it 6 months before replacement.
If you have TPMS I would be more inclined to stretch it a bit. Likewise any day even with new tires you can pick up something and lose pressure. And then I have lost the whole steel cap with no loss of pressure.
The damage to your RV can be significant as the tire comes apart.
Your call. Just be happy they all look great as that is the primary indicator that your alignment is good.
BTW typical ST tires are probably half the life at 3 to 5 years.
675w Solar pictures back up
joelc
Cedar Point, NC
Posted: 03/14/21 08:20am Link  |  Quote  |  Print  |  Notify Moderator
The tires on trailers/5th wheels do not wear the same as automotive tires. It is very possible that the tire can look practically new after many years use, but it is recommended that they be replaced every 6-7 yrs. or could be subject to failure.
garyemunson
Reno, Nevada
Posted: 03/14/21 09:18am Link  |  Quote  |  Print  |  Notify Moderator
A full set of tires is far cheaper than the damage one that blows out at speed can do.
Diamond c
West ky
Posted: 03/14/21 02:11pm Link  |  Quote  |  Print  |  Notify Moderator
From what I’ve seen over the years is that trailer tires dry rot way before they where out.
cummins2014
Utah
Posted: 03/14/21 07:43pm Link  |  Quote  |  Print  |  Notify Moderator
Michelle.S wrote:
I was running the GY 17.5" G114s and was hoping for 5 years, but one let loose at 4 1/2 years. Always run at correct pressure with the TST 507 TPMS and every thing was normal till BANG and rubber flying every where. Now running Sailun tires.
Good choice on the Sailuns . I’ll run mine for six years .
Endricken
Alabama
Posted: 03/17/21 03:07pm Link  |  Quote  |  Print  |  Notify Moderator
I'm going to try to get 8 years out of my last almost 7 year old Michelin XPS Rib. (Michelin states replace after 10 years regardless of mileage) I lost one with a Wheel (!), and one to a Nail.
I'll let you know if this summer's travels prove me wrong....
Retired USAF
Silver 05 Dodge RAM LB CTD Dually 4Speed Auto SWD 3.73, Westin Sportsman Grill & Taillight Guards,Husky Mudguards, Retractable Ball Hitch, Onboard Air & Horns, MaxBrake - towing 2005 Keystone Montana Big Sky 3670 with Star Performance adapter
mtofell1
Oregon
Posted: 03/18/21 12:03am Link  |  Quote  |  Print  |  Notify Moderator
I just replaced mine at 5 years after watching a buddy have two blowouts on his 6 year old rubber. I suppose if they were Michelins maybe I'd go longer but the offshore **** they put on new trailers is just that. I rest a lot easier with a step up in load range, higher speed rating and new rubber. Well worth the $400 IMO.
Splashers3
Oakville, MD
Posted: 03/18/21 12:44am Link  |  Quote  |  Print  |  Notify Moderator
I got 9 years out of my XPS Ribs....until 1 blew out sitting in my driveway....no damage. I kept them covered, inflated a few PSI higher over the winter months, and applied 303 protectant quite often.
2017 GMC 3500 Sierra Denali, C/C, D/A, DRW, w/40gal Aux tank, 18K B&W Patriot.
2019 Cedar Creek Hathaway, 34RL2 - w/Bells & Whistles and disc brakes
Traded 2009 Cedar Creek Silverback, GII, 32 WRL
kennethwooster
Perryton Tx USA
Posted: 03/18/21 09:24am Link  |  Quote  |  Print  |  Notify Moderator
I’ve never blown a tire but I change tires 5-6 years and watch the air pressure. I’m also careful concerning the brand of tire I buy. Too I store my trailer in an enclosed structure. Keeping tires out of sunlight helps a lot.
kenneth wooster- retired farmer. Biblical History Teacher in public HS, and substitute teacher.
wife Diana-adult probation officer, now retired.
31KSLS Full Body paint Cameo
Ford F350 2014 DRW 4X4 King Ranch.
20K B&W Puck mount hitch
 > Tire life
