RV.Net Open Roads Forum: Tech Issues: Fridge Fan (rear) help.
 > Fridge Fan (rear) help.
jmbstudios
Sunny Southwest
Posted: 03/13/21 09:24pm Link  |  Quote  |  Print  |  Notify Moderator
Hello all..
I have a 2018 Genesis 32CR Toy Hauler.
The fan on the back of my fridge is loud. So loud you can hear it from the bedroom and the better half has bat ears so it's gonna get replaced.
I'd like to replace it with a higher volume fan, possibly a computer fan.
My fridge does not have access from the outside.
For these fridges, am I able to pull the fridge out and disconnect the gas and electric?
Or does that need to be done from the access hole on the bottom of the toy hauler?
Also, has anyone replaced the rear fan? Which fan did you use?
Thanks in advance.
2019 F250 Lariat FX4
2018 Genesis Supreme 32CR
PRS and Taylor Guitars
dougrainer
Carrolton, Texas
Posted: 03/14/21 07:55am Link  |  Quote  |  Print  |  Notify Moderator
You have to pull the refer. Disconnect the 120 and the 12 volt and the LP line and remove the mounts screws inside the RV and the ones outside on the rear refer base plate. No other way. Doug
bighatnohorse
Gig Harbor - Cave Creek
Posted: 03/14/21 08:37am Link  |  Quote  |  Print  |  Notify Moderator
I'm looking at replacing the very loud fan in my Norcold.
So far, I'm looking at two possible replacement candidates:
Titan 12 volt on Amazon
and
AeroCool on Amazon
2021 Arctic Fox 1150
'15 F350 6.7 diesel dually long bed
Eagle Cap Owners
“The best lack all conviction, while the worst
Are full of passionate intensity."
-Yeats
garyemunson
Reno, Nevada
Posted: 03/14/21 09:03am Link  |  Quote  |  Print  |  Notify Moderator
I put two of these behind the top fridge vent. I wired them in series to slow and quiet them down. We had been camping in the Southwest a lot a couple years ago and I was wanting to move more air. Work beyond my expectation, the fridge stayed cold in 100+ degree days.
https://www.ebay.com/itm/Universal-9-inch-12V-80W-Slim-Push-Pull-Electric-Radiator-Cooling-Engine-Fan-Kit/154127885081?_trkparms=ispr%3D1&hash=item23e2bce319:g:Gx4AAOSwv9pfQAWb&amdata=enc%3AAQAFAAACgBaobrjLl8XobRIiIML1V4Imu%252Fn%252BzU5L90Z278x5ickkxGz2ccqatkEnoeekHqhLkds0njexIh9xtwk9DIHqppb%252BNv4ItQibIoz35eKcrHB4r90%252BaU8BXiLJymrWMuvSE4%252FXhDHYEh4ApgrpfZJ4lRVE%252BuIbahyX0ZPb9zzj%252FtyczhSfRozpWYk4OieXAdW8DEVdEyZNxAaCeuroNwn78PSM%252BBOj9EEyPI9tx1UskFbXDoqyf0nxlfvERo8qhbP3WTDaB6KhMgjomG%252Br2r%252FJ6%252FnFh6Cm4kRslVXssSfrHOAR8g68p4ElL3qPvzfzeqZZ%252Byf6IMgh%252Bd6yqv6oOMULnkvZt9mFT41cuqN%252Fj4wR0m9q5gFcwbm0gJXo%252Be%252FYqgdxopiUmNNuyHwSTeXJrzdKmTkRPV9czK6eqwjLS8SqQMcbcTPr8UHHIfznsOqSq7Ssf3adiP%252BJsuqFp7SY8FSH8zpOcyu8IryXSm1%252BV9KKmMwlX46swsNHqHJpPiJY9ELpo8fqH766nWRz9D1XqBMzhvZktK7ZVgxrXc9oeZuP9xK11wE8JnUyu5KFDBetBNLuRGfhz3q9psJDtHnF1DECH2%252FFEPXWS9IA9WuXLntJJ1IVRwQPyU1eSHZGTg30RWXGfQlXjxePNqUhlqw7HLYNdHXOaWYUIwnjpMliGDT9jC9Bz95tlfBdpX0zKL%252Bud1kkaqS2tLBRIaI2RzvPnlvskppyNeTH4mb4l1lGTaxiGh4lu%252F%252FQUmaXemHEhbJxFVAOJpPUmqZhxX7b6vYQYUd4J7tvOZSSzr4P1oWPekCyNxo%252BJbK1fJwRKh1N%252B7apHe3J6tOUSRjws69rxgkKU43H3oE%253D%7Ccksum%3A154127885081709e9811a516408d88ff40318c41cad0%7Campid%3APL_CLK%7Cclp%3A2334524
* This post was edited 03/14/21 09:10am by garyemunson *
garyemunson
Reno, Nevada
Posted: 03/14/21 09:09am Link  |  Quote  |  Print  |  Notify Moderator
This was the result. Used two aluminum bars to mount them, used the original thermostat, left the two old noisy fans disconnected but in place. These move enough air any obstructions are meaningless.
jmbstudios
Sunny Southwest
Posted: 03/14/21 10:51am Link  |  Quote  |  Print  |  Notify Moderator
Thx Doug. Only thing is that I don't have an outside. Only a small vertical soffit area that runs from the roof down to the floor. There is a small opening underneath.
scottykrug
Aurora, CO
Posted: 03/14/21 12:20pm Link  |  Quote  |  Print  |  Notify Moderator
Very impressive garyemunon. I bet those move serious air.
2009 Ram 3500 Mega 6.7TD
2015 Puma Palomino 295BHSS
Copilot (DW) Navigator (DD) Flight Engineer (DS)
