RV.Net Open Roads Forum: Fifth-Wheels: Would you do it?
 > Would you do it?
camperforlife
Midwest
Posted: 03/16/21 07:34pm Link  |  Quote  |  Print  |  Notify Moderator
Pairing a 2021 GMC Sierra 2500 HD 6.6 gas and a Grand Design Reflection 320MKS.
Trailer is 10495 dry, 13995 GVWR and a dry pin weight of 2040. Truck GVWR 10450, GCWR 24000, RGAWR 6390, Curb 7078. Max payload 3372.
Fifth Wheel tow max 16650 and max pin of 2490.
The only issue I am seeing is the possibility of fully load being over the pin weight by 2-300 lbs if not loaded properly. Probably use a Anderson hitch to keep the weight down.
Anything I'm missing? I'm not looking for the get a 3500 comments, I'm asking if I'm missing anything that looks out of line besides being close on the pin weight. Thanks in advance.
* This post was edited 03/17/21 07:34am by camperforlife *
MNRon
Tennessee
Posted: 03/16/21 08:27pm Link  |  Quote  |  Print  |  Notify Moderator
2500 vs 3500 is really just about pin weight, which you already have a handle on. Frankly, for the small upcharge I’d get the 3500, but I digress...
The only question that stands out to me is ‘gas’? I pulled a 9000lb TT with a 3/4Yukon, pulled well except on a steep grade out west, but couldn’t pass a gas station for my life; it got 7mpg. Now I pull a 16000lb 5er with a diesel, hills are no problem and 10-11mpg is constant.
I’d seriously consider a diesel, it will put a smile on your face when you pull [emoticon]
Ron & Pat
2022 F350 Lariat CCSB SRW Diesel
2019 VanLeigh Vilano 320 GK
camperforlife
Midwest
Posted: 03/16/21 08:43pm Link  |  Quote  |  Print  |  Notify Moderator
I get that but the mileage difference between the diesel and gas isn't that great any longer, diesel is significantly higher where I live and then there's that 9K upcharge. For the number of miles that I'm going to tow the diesel just doesn't make financial sense. The new 6.6 gas numbers are impressive.
time2roll
Posted: 03/16/21 08:52pm Link  |  Quote  |  Print  |  Notify Moderator
What else do you expect to carry in the truck? Four big adults? Tool box? Generator?
I think your max pin could easily get to 2700-3000 depending on how and what is loaded. Never seen a max pin rating.
Yea I would probably go for it but hard to recommend it to someone else. By the time you get it on a scale all the numbers may actually work but hard to say for certain.
675w Solar pictures back up
valhalla360
No paticular place.
Posted: 03/17/21 05:00am Link  |  Quote  |  Print  |  Notify Moderator
You are probably pushing the limits on the overall payload also.
Why are you getting a new truck but purposely getting one not suited to the expected use?
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
Lantley
Ellicott City, Maryland
Posted: 03/17/21 05:24am Link  |  Quote  |  Print  |  Notify Moderator
My thought as well. Get Bigger truck, bigger engine. Get a truck that will do the job vs. a truck that will be barely adequate.
19'Duramax w/hips,12'Open Range,Titan Disc Brake
BD3,RV safepower,22" Blackstone
Ox Bedsaver,RV760 w/BC20,Glow Steps, Enduraplas25,Pedego
Correct Trax,Splendide
ACZL
UPstate,NY
Posted: 03/17/21 05:53am Link  |  Quote  |  Print  |  Notify Moderator
Why not take a truck off dealer lot (similar to what you are looking at) filled w/ gas to a CAT scale to see what it actually weighs. Then you'll know for sure beforehand if your numbers will agree. I suspect the truck will be in neighborhood of 7700-8000 which would leave you not a whole heck of a lot of room on truck's GVW w/ "advertised" dry pin weight.
Let us know how you make out.
2017 F350 DRW XLT, CC, 4x4, 6.7
2018 Big Country 3560 SS
"The best part of RVing and Snowmobiling is spending time with family and friends"
"Catin' in the Winter"
padredw
East Texas
Posted: 03/17/21 06:01am Link  |  Quote  |  Print  |  Notify Moderator
I guess I'd have to say, I'm doing it, but I'm not telling anyone else to do it.
Your weights are very close to mine. I have been towing this 34' HitchHiker II for 14 years (see my travel map). We have towed over most of the passes in Colorado and many others in the western states. Two times in emergency situations we have had to tow without trailer brakes--once over Monarch Pass. The other time we had to tow back home from Coastal Georgia to East Texas (weekend and need to get home. No repair available). I would never advise to tow without trailer brakes, but I can say (like the Bumblebee) I was able to do it when I had to.
We have a 2017 Chevrolet Duramax diesel. We have actually been towing with a 2500 diesel with 4 different fifth-wheels for over 20 years, but we have towed this HitchHiker with the Chevrolet 2500 for over 100,000 miles. I have never felt any lack of control or stability on the highway or over high mountain passes.
Of course I'm pretty experienced: almost 200,000 miles of fifth-wheel towing and 88 years of age! [emoticon] [emoticon]
Sjm9911
New Jersey
Posted: 03/17/21 06:24am Link  |  Quote  |  Print  |  Notify Moderator
I will not coment on the towing aspect. But the gas tank is huge, so you can probably get 250-300 miles on a tank at 7-8 mpg.
2012 kz spree 220 ks
2020 Silverado 2500
Formerly a pup owner.
MFL
Midwest
Posted: 03/17/21 07:00am Link  |  Quote  |  Print  |  Notify Moderator
While most would not consider that rig matchup to be ideal, it is certainly do able. With a GCWR of 24,000, GM is saying the drivetrain is capable. You will need to stay within RAWR/tire rating. At full FW GVWR, that may be close. At the gross wt you listed in your recent post, likely no problem.
The new GM 2500 HD is a stout truck, almost a 3500 in capability and higher than normal class 2 ratings.
Nothing wrong with the Andersen hitch, if that is what you want. Another good option is the 3700 for GM oem puck system. It is not too heavy, and manageable for one person in/out, as it easily separates in two pieces.
I don't see a real problem in your choice!
Jerry
* This post was edited 03/17/21 08:01am by MFL *
 > Would you do it?
