RV.Net Open Roads Forum: Tech Issues: Battery Percentage Before Charging.
 > Battery Percentage Before Charging.
time2roll
Posted: 03/17/21 02:48pm Link  |  Quote  |  Print  |  Notify Moderator
Yes leave a couple lights on. If you discharge extremely slow you may count more amp/hrs compared to when you are actually using the RV. The small draw you post is virtually at rest so the battery scale of voltage is a bit different. Such as 12.06 might be 50% in normal usage but would be only 25% charge in your virtual rest experiment.
The 12 Volt Side of Life
675w Solar pictures back up
1L243
Oregon
Posted: 03/17/21 08:16pm Link  |  Quote  |  Print  |  Notify Moderator
I just spoke with the research and development department (me) and it was decided to postpone the low voltage test to prevent unnecessary damage due to sulfation.
We will be having real world testing soon enough..
Thank for the input..
2017 Coleman 300tq by Dutchman Toy Hauler. 34.5 feet long and under 10k Gross. 500 watt Solar 2000 watt Inverter, 1999 Ford F250 2WD 7.3 4R100 DP Tuner, S&B Cold Air Intake, Gauges, 6.0 Trans Cooler, Air Bags.
