RV.Net Open Roads Forum: Fifth-Wheels: Towing with Dodge short bed
 > Towing with Dodge short bed
dieseldan723
Pacific NW
Posted: 03/16/21 08:45pm Link  |  Quote  |  Print  |  Notify Moderator
Good evening,
I have had two GMC short box trucks and used a Pull-Rite sliding hitch with ZERO problems. I am now looking at a new Dodge with a short box. The Dodge is two inches shorter than the GMC's I have previously owned.
I am open to another sliding hitch. Is there any issue with this setup that I should be concerned about?
Thank you all for your great advice!
Currently looking for my next RV....
SOLD
2014 Keystone Fuzion 301 towed by 07 GMC Sierra 2500HD Classic CCSB 4X4
2012 Komfort 3530FBH towed by 08 Chevy 3500HD DRW
2006 Forest River Cardinal 33TBH towed by 03 GMC 2500HD
Prodigy 3 brake controller
LadyRVer
Posted: 03/16/21 09:09pm Link  |  Quote  |  Print  |  Notify Moderator
I used a slider in a short box and when I slid the hitch back and started to manuver, the pin box caught the tail gate... did a number on it. First time I ever used the slider... before that was super careful in backing/turning.
Ed9824v
Agua Dulce, Calif. 70 mi N.E. of Los Angeles
Posted: 03/16/21 10:11pm Link  |  Quote  |  Print  |  Notify Moderator
I use a pullrite slider in my 98 Dodge Ram shortbed 2500 always clears
Ed So.Calif
1950 Ford F1 street rod
1968 Baha Bug with 2.2 ecotec motor 170 hp, kingcoil
2000 National Sea Breeze 5th wheel trailer
1998.5 Dodge 2500 4x4 Cummins,4.10 gears,turbo,trans,injectors,oil cooler,lockers,edge EZ, 35" BFG's, air dog lift pump etc.
JIMNLIN
Oklahoma
Posted: 03/17/21 07:34am Link  |  Quote  |  Print  |  Notify Moderator
What year model was your Dodge/Ram truck and was the pin located over the rear axle or behind the rear axle.
cummins2014
Utah
Posted: 03/17/21 08:45am Link  |  Quote  |  Print  |  Notify Moderator
dieseldan723 wrote:
Good evening,
Yes ,its a 6'-4" bed , and I have no problems towing my fifth wheel without a slider . My truck is the 2014 Ram Megacab ,same bed length as the Ram crew cab short bed. I have two hitches , my older Reese 18K slider ,that I have pretty much quit using, and the Andersen hitch, which is a fixed hitch, although it does have four different tow positions.
Having said this ,it will depend a lot on the type of fifth wheel, and the pin box position. My present fifth wheel has some very rounded front corners ,and the pin box extends out a little further then my previous fifth wheel. Although both fifth wheels did not require a slider. Both were towed with the Andersen without issue . Good luck with your choice .
dieseldan723
Pacific NW
Posted: 03/17/21 08:57am Link  |  Quote  |  Print  |  Notify Moderator
The Dodge 3500 I am looking at does not come with the 5th wheel prep package. I assume this will give me a bit more flexibility on what hitch I can use. In two previous trucks I installed the Pull-Rite myself. I won't be doing that on the new truck.
Please give me any opinions on which hitches I should be considering. I haven't been in the 5th wheel world for over 10 years! (It's good to finally be empty nesters!)
dieseldan723
Pacific NW
Posted: 03/17/21 09:00am Link  |  Quote  |  Print  |  Notify Moderator
cummins2014 wrote:
dieseldan723 wrote:
Good evening,
Good information. We haven't actually purchased our 5th wheel yet, however we have our heart/mind set on the Cedar Creek 388DB.
cummins2014
Utah
Posted: 03/17/21 09:01am Link  |  Quote  |  Print  |  Notify Moderator
It also depends a lot on the pin box. I have towed two different fifth wheels with my Andersen hitch , same truck . My previous fifth wheel I towed with the adapter putting the fifth wheel further from the cab ,closer to the tailgate without a problem. The length of the pin box on my present fifth wheel, I reversed the adapter putting the fifth wheel closer to the cab , further from the tailgate, pin box when hooked up with the previous position of the adapter ,it appeared too close to the tailgate. I didn't even attempt to tow with it ,I just reversed the adapter. I have no problem with cab clearance in that position .
cummins2014
Utah
Posted: 03/17/21 09:18am Link  |  Quote  |  Print  |  Notify Moderator
dieseldan723 wrote:
cummins2014 wrote:
dieseldan723 wrote:
Good evening,
I see that fifth wheel has a 18,000 GVWR ,thats pushing a SRW 3500 Ram truck as far as weight, considering you are going with a short bed ,unless are you looking at the Megacab 3500 dually , only short bed dually I am aware of ??
As far as hitches , I see you are going with the fifth prep , my Ram 3500 has the fifth prep, but in 2014 the choices were limited on hitches, so I went with the adapter frame that goes attaches to the puck system. ,to attach a standard rail hitch . I have since went with the standard rail steel Andersen that also attaches to the adapter. knowing what I know about some of the single point hitches now, I would still go, although some will disagree ,with the adapter ,and a four point steel Andersen hitch. It works well for me with a short bed .
You will get some good advice from others ,that also work well, I have been a few different ways with hitches ,and prefer what I have done. The next best thing would be, "IF" Andersen would come out with a four point hitch that goes to the puck system on these trucks .
dieseldan723
Pacific NW
Posted: 03/18/21 12:09am Link  |  Quote  |  Print  |  Notify Moderator
Cummins2014, thank you for the information. According to the Dodge website, when I enter the VIN of the truck I am considering, it says the Max Payload is 3954 lbs and the Max Towing is 24,734. I thought I would be fine with that trailer?
Thoughts?
Here is the website https://www.ramtrucks.com/towing/towing-guide.html
Click on the "Look Up My Vehicle" and enter a VIN.
