RV.Net Open Roads Forum: Travel Trailers: Water Hookup Order
 > Water Hookup Order
kellem
Shenandoah valley,VA
Posted: 03/17/21 05:17pm Link  |  Quote  |  Print  |  Notify Moderator
Zero G is a great choice....use them around the house as well.
Lynnmor
Red Lion
Posted: 03/17/21 06:13pm Link  |  Quote  |  Print  |  Notify Moderator
I put a hook under the trailer and hang the filter there out of the hot sun and out of the way. The regulator and a Y are at the hydrant.
beemerphile1
Ohio
Posted: 03/17/21 06:24pm Link  |  Quote  |  Print  |  Notify Moderator
hydrant - hose - filter - regulator - 6' hose - RV
This keeps the filter and regulator beside the RV. As someone who has had to rebuild industrial regulators due to a tiny speck of grit, my regulator goes after the filter. I use a whole house filter rated to handle high pressure.
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
philh
Belleville MI
Posted: 03/17/21 08:14pm Link  |  Quote  |  Print  |  Notify Moderator
I'm overly cautious and always run off onboard water. Too many horror stories of leaks destroying RV.
Cocky_Camper
Rock Hill, SC
Posted: 03/18/21 08:16am Link  |  Quote  |  Print  |  Notify Moderator
I use the regulator at the camper side. If you are in the direct summer sun, those hoses expand and build up pressure which is causing increased pressure inside also...
2004 Sea Breeze by National RV - 8341
Former Coaches:
2006 Keystone Zeppeline 291 - TT
2000 Aerolite Cub F21 - Hybrid TT
1991 Coleman Pop Up
Formerly known as: hybrid_camper
Boomerweps
Hills of PA
Posted: 03/18/21 09:30am Link  |  Quote  |  Print  |  Notify Moderator
MarkTwain wrote:
midapo wrote:
Hello all! We are back in the RV Community after 15 years or so. Please consider us newbies. We just bought a 2018 K-Z Connect 251RK and are looking forward to our first trip!
Question: All the videos and articles I have seen say to hook my pressure regulator and water filter up at the supply. The pressure regulator is fine but it seems to me that it would be better to hook up the water filter at the camper. The water will at times sit in the hose for hours when it is not being used. Wouldn't you want to filter that water? Am I missing something? Thanks!
I want the weight of the water filter on the water faucet not on the plastic connector on the side of the RV.
I use a Camco Evo something large free standing with bracket water filter and a 10’ hose at the trailer side, NOT hanging a filter off the TT. Only extra on the TT is a metal 90 degree adapter then hose.
2019 Wolf Pup 16 BHS Limited, axle flipped
2019 F150 4x4 SCrew SB STX 5.0 3.55 factory tow package, 7000#GVWR, 1990 CC Tow mirrors, TBC
cougar28
Lowell,AR USA
Posted: 03/18/21 06:03pm Link  |  Quote  |  Print  |  Notify Moderator
If that would cause a pressure problem what kind of problem is your water heater causing?
2002 F-250 SD CC 7.3PSD Auto. XLT Short Bed 4X4 Off-Rd.Pkg.Highland Green,Westin Sportsman Grille Guard (Black) RBW Li'l Rocker Slider ,Prodigy Control Towing Jayco Eagle HT 30.5 MLOK,Handy 5er tailgate
Kevinwa
Western canada
Posted: 03/18/21 06:16pm Link  |  Quote  |  Print  |  Notify Moderator
Spigot, wye, filter, regulator, 10’ hose camper.
I use the second side of the wye to rinse off my dusty and maybe sweaty mountain bike helmet, gloves and knee pads when I get back from a ride.
I like the regulator downstream of the filter, as I feel that I get better flow through the filter when it is on the high pressure side. I also carry a long hose, but have only needed it once in the last eight years...
LVJJJ
NW WASHINGTON
Posted: 03/19/21 08:14am Link  |  Quote  |  Print  |  Notify Moderator
Hook up at the supply, just a regulator and blue filter. Got a Zero G hose when they first came out, love it.
1994 GMC Suburban K1500
2005 Trail Cruiser TC26QBC
1965 CHEVY VAN, 292 "Big Block 6" (will still tow)
2008 HHR
L(Larry)V(Vicki)J(Jennifer)J(Jesse)J(Jason)
