RV.Net Open Roads Forum: Travel Trailers: Water Hookup Order
 > Water Hookup Order
midapo
Kilgore, Tx
Posted: 03/17/21 10:43am Link  |  Quote  |  Print  |  Notify Moderator
Hello all! We are back in the RV Community after 15 years or so. Please consider us newbies. We just bought a 2018 K-Z Connect 251RK and are looking forward to our first trip!
Question: All the videos and articles I have seen say to hook my pressure regulator and water filter up at the supply. The pressure regulator is fine but it seems to me that it would be better to hook up the water filter at the camper. The water will at times sit in the hose for hours when it is not being used. Wouldn't you want to filter that water? Am I missing something? Thanks!
1996 26' Prowler Fiver
1994 Mint F-350 Diesel
2 Kids 2 Dogs (interchangeable)
schlep1967
Harrisburg, PA
Posted: 03/17/21 10:51am Link  |  Quote  |  Print  |  Notify Moderator
That water sitting in the hose would have already been filtered. If you are using a drinking water safe hose, the hose should not add anything that needs filtered out.
You could do a 2 filter system with a sediment filter pre-hose and a charcoal/taste filter after if that is what you are going for.
2008 Dodge Ram 2500 Diesel
2009 Open Range 385RLS
Pull-Rite Super Glide
time2roll
Posted: 03/17/21 10:57am Link  |  Quote  |  Print  |  Notify Moderator
Anything the hose leaches into the water will not be caught in the filter anyway. Should have no issues with a potable water rated hose.
675w Solar pictures back up
jdc1
Rescue, Ca
Posted: 03/17/21 11:10am Link  |  Quote  |  Print  |  Notify Moderator
It's no different than the water sitting in all that PEX water line in your RV.
Boomerweps
Hills of PA
Posted: 03/17/21 11:17am Link  |  Quote  |  Print  |  Notify Moderator
I put everything near the camper. That way I’m more likely to look at it occasionally. If using the non metered flow regulator, that might be placed on the supply faucet.
2019 Wolf Pup 16 BHS Limited, axle flipped
2019 F150 4x4 SCrew SB STX 5.0 3.55 factory tow package, 7000#GVWR, 1990 CC Tow mirrors, TBC
Sjm9911
New Jersey
Posted: 03/17/21 11:32am Link  |  Quote  |  Print  |  Notify Moderator
I rather not have the extra weight hanging off the TT. I put both on the campsite spigot. Along with a wye.
2012 kz spree 220 ks
2020 Silverado 2500
Formerly a pup owner.
kellem
Shenandoah valley,VA
Posted: 03/17/21 12:49pm Link  |  Quote  |  Print  |  Notify Moderator
I also hang everything at the supply.
midapo
Kilgore, Tx
Posted: 03/17/21 01:12pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks! I did buy the Zero G water hose, so I am sure it will be fine. I was thinking about drinking from a water hose when I was a kid and the plastic taste it had. Maybe that's why I have seemed to have lost a few brain cells!
Sjm9911
New Jersey
Posted: 03/17/21 01:49pm Link  |  Quote  |  Print  |  Notify Moderator
I got the zero g last year and like it a lot. Put my old hose is in the camper in case i need extra length. The zero g is pretty nice, lightweight and so far is better for me, take up less space. I liked it so much a bought an expandable ( i know there diffrent) for the black tank clean out and to use around the campsite.
MarkTwain
Northern, Ca. , USA
Posted: 03/17/21 03:53pm Link  |  Quote  |  Print  |  Notify Moderator
I want the weight of the water filter on the water faucet not on the plastic connector on the side of the RV.
