RV.Net Open Roads Forum: Towing: 1/2 Ton Limit
Search only in Towing
Open Roads Forum  >  Towing
 > 1/2 Ton Limit
Sjm9911
New Jersey
Posted: 03/18/21 12:39pm Link  |  Quote  |  Print  |  Notify Moderator
goducks10 wrote:
Sjm9911 wrote:
That was always very common, especially in pop ups , not sure how it is with TT. The published weigjts were out of the factory, anything added at the dealer was extra weight. So everything was an add on. But it does list tanks adding up to 190 gallons, so black, greay and fresh, filling those at 8.3 gallons adds 1570 or so lbs. So it needs a high gvwr or you would not be able to use the tanks it has.
Explain a common situation where you'd travel with all 3 tanks full.
We dry camp, water/elec camp and FH camp. When dry camping we empty our 80 gal fresh into the black and grey. So only 80 gal total.
When we FH camp we dump the grey and black and may fill the fresh if we're heading to a dry camping spot.
If we're on water/elec only then the fresh is not filling and we would dump the grey and black leaving nothing or again maybe filling the fresh for future use.
In our short 11 years of RV'ing we've never had all 3 tanks full at once.
There isn't one. , I was just stating the capacity of the tanks, if you travel with them full. I have traveled like that one, due to no dump station between trips and filling my fresh water before the next one. Had to dump where i could. Just because there isnt a need dosen't mean they dont have to build that into the weight carring capacity.
2012 kz spree 220 ks
2020 Silverado 2500
Formerly a pup owner.
Gene K 2
Posted: 03/18/21 04:32pm Link  |  Quote  |  Print  |  Notify Moderator
APT wrote:
6k dry is my standard recommendation for the more capable half tons. People that but 7kdry+ and have someone like your truck generally report some form of stability issues when towing @highway speeds. There are exceptions for certain needle in haystack half tons like Ford's Max Payload package or GM's NHT package. That GD 2250 is 5500 pounds dry, Even at 7k loaded, 1000 pound TW, you have 900 pounds of payload to load in on cab and bed. Seems like plenty of margin to me. [emoticon]
Well seeing as how it was placarded for 6,995 until just recently it does at least meet my Grandfather's old smell test of Trailer Weight = Truck GVWR. I doubt he would be a fan of 14,000 lb Trailers and 7,000 GVWR Trucks.
mkirsch
Rochester, NY
Posted: 03/19/21 08:09am Link  |  Quote  |  Print  |  Notify Moderator
Gene K 2 wrote:
Thanks Guys...
I guess I'm gunshy because of all the sway issues I've read about with 1/2 tons and longer heavier travel trailers.
What about all the sway issues you've read about with 1/2 tons and shorter trailers? Shouldn't that scare you away from towing altogether?
Frankly I am not sure what sway issues you've read about, because nearly all of the supposed "sway" I've read about on here is NOT SWAY. The trailer bobbles a little and comes right back in line. That's called rough road. That's called wind. That's called a large vehicle passing at high speed. If it didn't require active correction and/or did not kill you, it was NOT sway.
Besides if you take precautions and load the trailer with some common sense, you won't have sway to begin with. Use a good integrated sway control for "belt and suspenders" protection, and you have nothing to worry about.
Gene K 2
Posted: 03/19/21 04:59pm Link  |  Quote  |  Print  |  Notify Moderator
mkirsch wrote:
Gene K 2 wrote:
Thanks Guys...
I've seen it once or twice. I've not experienced it and would like to keep it that way.
Mike134
Elgin, IL
Posted: 03/22/21 07:24am Link  |  Quote  |  Print  |  Notify Moderator
Gene K 2 wrote:
mkirsch wrote:
Gene K 2 wrote:
Thanks Guys...
Please give more details, what were their estimated speeds, what was the final result, etc. for each one. Thanks
2019 F150 4X4 1903 payload
2018 Adventurer 21RBS 7700 GVWR.
Gene K 2
Posted: 03/23/21 02:24am Link  |  Quote  |  Print  |  Notify Moderator
1. Astro Van with a 19' (Box Length) Travel Trailer. 65 mph and regained control after dropping to 45-50 mph.
2. S-Blazer 4-Door with 19' (Box Length) Travel Trailer. 65 mph and regained control after dropping to 45-50 mph.
3. Explorer with 24' (Box Length) Travel Trailer. 70 mph and ended up upside down in the median.
Lengths are approximate and I don't know anything about how they had them loaded. The Explorer certainly looked marginal for that size trailer.
Mike134
Elgin, IL
Posted: 03/23/21 06:11am Link  |  Quote  |  Print  |  Notify Moderator
Apricate the info. All little vehicles, and as the 70 mph showed stability gets worse the faster you go.
blt2ski
Kirkland, Wa
Posted: 03/23/21 06:47am Link  |  Quote  |  Print  |  Notify Moderator
Tandem axle kenworth with 20' flatbed towing a tandem axle tilt deck with typical metal sheets for road ditch excavation covers. Could not go over 55-60 or trailer swayed.
Reality, longer the trailer on a given WB rig, closer tow rig is to being square, is length wb equal width of tires, the easier it is for a rig to have uncontrolled sway.
Or Kenworth mentioned, plates hung off rear to far, so trailer had unconrolled sway due to too low hitch wt. Have had issue behind a one ton dually flatbed, and my navistar with improperly loaded trailers too.
Hence where some of us back before gcwr ratings as they are known today went with
Max trailer WT of two times grawr.
Max gcw two times gvwr or three times grawr.
Biggest motor most gears in trans, lowest gears in axle.
Another rule of thumb
Max trailer 20' for wheelbase if iirc 110". Additional foot per 4" wb. Rule said not to pull with shorter WB rigs. But I would suggest smaller by a foot per 4".
This is for a ball mount car back in 50's 60's and before.
5w because it's over the RA, you should be able to go a bit longer. Heavier chassis also a bit longer in length.
There is way more to proper safe towing that fitting into a weight rating(s) in reality. Even the newish gcwr rating specs are not great imho on some of the specs.
Marty
2014 Chevy 1500 Dual cab 4x4
Posted: 03/23/21 09:16am Link  |  Quote  |  Print  |  Notify Moderator
^ Or to put Marty's experience into laymans terms, you can tow quite heavy with a smaller truck "if" its the right combination of weight, tongue weight, trailer axle placement, tow rig wheelbase, trailer length, etc.
And you can have issues with a bigger truck if the above considerations are "wrong."
As usual, no one size fits all answer. Hence why those who aren't as knowledgeable or don't care to get into the details often opt to "over truck" the combo, which generally never is a bad thing. Regardless of whether it's necessary or not.
2017 Heartland Torque T29
Gene K 2
Posted: 03/23/21 08:35pm Link  |  Quote  |  Print  |  Notify Moderator
I've pulled 11,000 before behind a 1/2 ton but I suspect a 36'+ Flagstaff might be an entirely different experience than a relatively short low profile load.
 > 1/2 Ton Limit
