RV.Net Open Roads Forum: Technology Corner: Anyone use Fototime for photo hosting?
 > Anyone use Fototime for photo hosting?
Page of 5
Gdetrailer
PA
Posted: 03/20/21 04:37pm Link  |  Quote  |  Print  |  Notify Moderator
BradW wrote:
AsheGuy wrote:
In spite of the many complicated solutions suggested here for putting a photo in a post, it's not that complicated. The simplest way is to use the RV.NET provided Photo Post & Upload website that properly sizes the photo and provides a link to copy and past here.
I need an easy solution that works on any forum, not just the rv.net forum.
With fototime, I could just right click on the photo and it copied a link to my clipboard that I could paste anywhere. I could post the image or a link to the image. I could also create albums containing photos for a certain topic, like a vacation and then easily copy and paste the link to the album anywhere.
Actually, you can use the RV.net photo posting is great for other websites..
You can copy entire URL from that app, then remove the RV.net forum specific parts. which is the beginning part where you see the brackets..
So what you would see as " bracket IMG bracket" at the beginning and " bracket /img bracket " at the end you can remove and now you have a photo usable on other websites.
So, a jpg I posted using the RV.net app would now look like this once I remove the RV.net formating..
https://i.imgur.com/cc5OEwzl.jpg
And it does work just by dropping that address above into your browser..
Here is that link setup as a clickable link HERE
Those photos are hosted on imgur.com and supposedly (I have not tried it) you are supposed to be able to manage them.. You could even sign up for imgur for your own account..
https://imgurinc.com/about
Gdetrailer
PA
Posted: 03/20/21 04:57pm Link  |  Quote  |  Print  |  Notify Moderator
2oldman wrote:
ImageEvent should do it for you.
[emoticon]
Read the TOS..
HERE
"ImageEvent provides space for Member Albums but makes no implied or express warranties about the reliability of these albums. ImageEvent is not responsible for any damage caused by loss of access to, or deletion or alteration of Member albums; individual Members are responsible for monitoring and creating backups of their albums.
DISCLAIMER
YOUR USE OF THE ImageEvent SERVICE, INCLUDING ANY MATERIALS, DATA OR INFORMATION POSTED, SUBMITTED, DOWNLOADED OR OTHERWISE OBTAINED THROUGH THE ImageEvent SERVICE, IS AT YOUR OWN RISK. THE ImageEvent SERVICE IS NEITHER DESIGNED NOR INTENDED TO BE USED AS A DISASTER RECOVERY FACILITY OR AS AN EMERGENCY DATA STORAGE FACILITY. ALTHOUGH ImageEvent TAKES REASONABLE PRECAUTIONS TO PRESERVE AND PROTECT THE MATERIAL YOU MAY UPLOAD TO THE ImageEvent SERVICE, YOU SHOULD NOT RELY ON THE ImageEvent SERVICE AS YOUR ONLY SOURCE FOR THE MATERIAL YOU PROVIDE. YOU SHOULD KEEP YOUR OWN BACKUP COPIES OF ALL MATERIALS YOU MAY USE, OR ALLOW OTHERS TO USE, IN CONNECTION WITH THE ImageEvent SERVICE, INCLUDING MATERIALS POSTED OR SUBMITTED TO THE ImageEvent SERVICE.
THE OPERATION OF THE ImageEvent SERVICE MAY BE AFFECTED BY NUMEROUS FACTORS BEYOND ImageEvent'S CONTROL. THE OPERATION OF THE ImageEvent SERVICE MAY NOT BE CONTINUOUS OR UNINTERRUPTED OR SECURE. SECURITY AND PRIVACY RISKS CANNOT BE ELIMINATED. PASSWORD PROTECTION MAY NOT PREVENT UNAUTHORIZED ACCESS TO MATERIALS YOU MAY USE OR ALLOW OTHER PERSONS TO USE IN CONNECTION WITH THE ImageEvent SERVICE, INCLUDING MATERIALS POSTED OR SUBMITTED TO THE ImageEvent SERVICE.
THE ImageEvent SERVICE IS PROVIDED ON AN "AS IS" AND "AS AVAILABLE" BASIS, AND WITHOUT ANY REPRESENTATIONS, WARRANTIES OR CONDITIONS OF ANY KIND, WHETHER EXPRESS OR IMPLIED, AND INCLUDING WITHOUT LIMITATION IMPLIED WARRANTIES OF TITLE, NON-INFRINGEMENT, MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE, PERFORMANCE, OR DURABILITY, ALL OF WHICH ARE HEREBY DISCLAIMED BY ImageEvent AND ITS SERVICE PROVIDERS TO THE FULLEST EXTENT PERMITTED BY LAW. "
Just because you have had no problem with your storage, doesn't mean it will be available or work forever..
Chances are, it too will eventually fall..
BradW
Mayor of Flat Rock
Posted: 03/20/21 04:58pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks, but I'm going with a big name photo hosting site this time.
Wake Up America
2019 Lance 1062 and 2018 F-350 CC PSD 4X4 DRW
Tembrens, Rear Roadmaster Sway Bar, Torklift 48" Extention and 30K Superhitch
Our New Lance 1062 Truck Camper Unloading at Dealer Photos
BradW
Mayor of Flat Rock
Posted: 03/20/21 05:33pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks, but that wouldn't work for me; too slow, too cumbersome. That might work for a photo or two, but I sometimes batch upload 100's of photos at one time. I also need to be able to set up albums with specific photos in it. Plus, rv.net could cut that off the ability to post photos on their web site on another forum at any time. Most forums which host photos already do that.
BobsYourUncle
Calgary Alberta Canada
Posted: 03/20/21 08:55pm Link  |  Quote  |  Print  |  Notify Moderator
Gdetrailer wrote:
2oldman wrote:
BobsYourUncle wrote:
I'm going to check it out and figure out how to do it.
Thanks!
See if you can display a google image here.
See if you can access from my links, here is some PDFs from my Google shared docs folder..
Homemade wire lugs..
Click HERE
My TT Rebuild PDF..
HERE
My 8700W gen sound test video (for those folks thinking the muffler is where the sound comes from)
HERE
If you can open up my PDF and video links, pix files will be no issue..
You do not "need" to use Google pix for sharing pictures either.. Just use the Google drive and set for sharing..
May take a couple of tries to get it working as it isn't 100% obvious on how to do it.. Thought about making a doc to show how it is done but by the time I would get it posted Google would most likely have changed how to set it up..
Yes, your links all work fine.
Thanks for the pointers.
Dmax/Allison
2007 Pacific Coachworks Tango 306RLSS - 32'
RV Rebuild Website
Site is live, finally launched Aug 22, 2021 @ 6:53 PM
2oldman
NM
Posted: 03/21/21 10:03am Link  |  Quote  |  Print  |  Notify Moderator
Which one? I didn't know there were any 'big names' in that business. [emoticon]
2oldman
NM
Posted: 03/21/21 10:11am Link  |  Quote  |  Print  |  Notify Moderator
Gdetrailer wrote:
[emoticon]
Read the TOS..
Everything is backed up. Settle down.
1492
Arlington, VA
Posted: 03/21/21 01:42pm Link  |  Quote  |  Print  |  Notify Moderator
Please do not use this for other websites. This app was meant for only this forum to help members who were struggling to include photos in their posts. The photo posting process here is so annoying even to myself, I decided to quickly put this together one night.
IMGUR.com sets a daily limit on the number of uploads using their API, and requires a request to increase the limit if they are exceeded. If the this app is not working on some occasions, it could be due to the daily limit being exceeded.
1492
Arlington, VA
Posted: 03/21/21 02:19pm Link  |  Quote  |  Print  |  Notify Moderator
2oldman wrote:
Thanks, but I mean display it on here sans links. 1492 did it but I'll be darned if I can figure out how.
Regarding posting Google Drive photos, I used the browser's developer tools to find the URL link.
However, there may be an easier way. A search found this tool that reports to convert a Google Drive photo link to a URL link you can use to post photos.
Just note that since Google is not providing the URL hotlink directly, they could change the link method used to access the photos at any time.
Sample Google Drive photo using the above app (https://drive.google.com/uc?id=1nAYngkZNrW64lGp7R6dvhNYiURaSR_qI):
AsheGuy
Raleigh, North Carolina
Posted: 03/21/21 03:19pm Link  |  Quote  |  Print  |  Notify Moderator
I use Google Drive for all non-photo document needs, but I just don't understand what Google Drive brings to photos. I guess I am dense, but Google Photos meets ALL my photo needs. In either case, the photos are in the Google Cloud and the two apps are just the tools Google offers to manage/access them.
Information on the subject: Google Drive vs. Google Photos: What's the difference?
David & Margaret - 2005 LTV 210B 3S
- Our Blog -
Page of 5
