RV.Net Open Roads Forum: Towing: Need more tongue weight
Search only in Towing
Open Roads Forum  >  Towing
 > Need more tongue weight
Flapper
Minnesota
Posted: 03/19/21 03:24pm Link  |  Quote  |  Print  |  Notify Moderator
Or just spend the big money and get a ProPride hitch. It will give a lot of weight up front, AND guarantee that sway cannot happen. That ended up being my only option in a similar situation. Makes towing a trailer fantastically better!
2012 F150 Eco, 4x4, SCrew, Max Tow, HD Payload
2017 Grand Design Imagine 2670MK
Seon
Lake Camanche, CA
Posted: 03/19/21 04:07pm Link  |  Quote  |  Print  |  Notify Moderator
1+ on the tray and mount a 3k generator then add a second battery and dual 30# Propane tanks.
That's what I did.
PastorCharlie
NC
Posted: 03/19/21 05:40pm Link  |  Quote  |  Print  |  Notify Moderator
IF the storage tanks are up front and IF you are going to a campground then fill them with water which can be dumped once in campground.
Gene K 2
Posted: 03/19/21 05:47pm Link  |  Quote  |  Print  |  Notify Moderator
I've seen people with a piece of bar stock welded or clamped vertically to the tongue or a-frame with barbell weights on it. Not on a travel trailer but on other trailers.
phillyg
SWFL
Posted: 03/19/21 07:22pm Link  |  Quote  |  Print  |  Notify Moderator
This is the first time I've ever seen anyone ask about adding weight LOL. Have you actually weighed? At 15%, or 930lbs based in your numbers, you need to add a lot more than one battery.
--2005 Ford F350 Lariat Crewcab 6.0, 4x4, 3.73 rear
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
LITEPHIL
AZ
Posted: 03/19/21 10:48pm Link  |  Quote  |  Print  |  Notify Moderator
As I had said. I want to add couple hundred pounds. 15% works best but I'll be happy adding 200 lbs.
2019 Chevy RST Silverado 1500
1954 Chevy 3100 Carryall 4x4
2002 Sandpiper T22
04 FXDL Harley
LITEPHIL
AZ
Posted: 03/19/21 10:51pm Link  |  Quote  |  Print  |  Notify Moderator
Got some ideas. I really wish the openings for the front pass through were bigger so I could load the compartment down. I would have to turn a battery sideways to get it through the opening.
Thank you all.
BenK
SF BayArea
Posted: 03/19/21 11:41pm Link  |  Quote  |  Print  |  Notify Moderator
In conjunction to adding tongue weight...redo your hitch setup to lower the tongue pointing down, below level.
That increases the caster of the trailer and it will follow better
-Ben Picture of my rig
LITEPHIL
AZ
Posted: 03/20/21 12:22am Link  |  Quote  |  Print  |  Notify Moderator
Yes, I always set my trailer around an inch lower in the front than rear and measured at the frame.
All this thing needs is a little more weight in the front and it will be good. I've put a few thousand miles on it and it's just not the trailer that you forget is there.
Thanks!
Mich upnorth
Niles, MI
Posted: 03/20/21 03:43am Link  |  Quote  |  Print  |  Notify Moderator
Is there any way to access the pasthrough compartment through the couch and put larger things in that way?
Bob & Barb
2019 F-150 Ecoboost Lariat Crewcab
2014 Coachman Catalina 30RLS
ProPride hitch
