RV.Net Open Roads Forum: Towing: Need more tongue weight
Search only in Towing
Open Roads Forum  >  Towing
 > Need more tongue weight
Turtle n Peeps
California
Posted: 03/22/21 10:36am Link  |  Quote  |  Print  |  Notify Moderator
mkirsch wrote:
So to all of you who suggest putting things like propane, beer, water, and other CONSUMABLES up front for tongue weight...
What happens when you burn up all the propane and drink all the beer???
Apparently trailers don't sway on the trip home, only on the way out.
I would take the trailer back to where I bought it and COMPLAIN. Get your money back. Their fix will be to add dead weight to the front. Tell them that this is not acceptable.
Aaaaaaaa, I would just buy more beer! [emoticon]
outside the fire"
"The best way to get a bad law repealed is to enforce it strictly."- Abraham Lincoln
hkkarlsson96
utah
Posted: 03/22/21 01:34pm Link  |  Quote  |  Print  |  Notify Moderator
Calculating your targeted tongue weight can be a NIGHTMARE, but the information included in this post helped me out allot, so I thought I'd share! I'm a big fan on how in depth some of these posts go!
https://towingpeaceofmind.com/forums/topic/towing-within-your-target-tongue-weight/
BenK
SF BayArea
Posted: 03/22/21 01:46pm Link  |  Quote  |  Print  |  Notify Moderator
Another possible and will not add much weight to the trailer...
Move the axle assembly BACK towards the rear
How much will take some mechanical engineering.
My guess something in the neighborhood of 6”-8”
Trailer OEM’s, in general, has the trailer axle assembly center line too close to the coupler and IMHO, reduces the tongue weight. At the cost of towing manners.
-Ben Picture of my rig
LITEPHIL
AZ
Posted: 03/22/21 07:23pm Link  |  Quote  |  Print  |  Notify Moderator
Thought about that and I could do that but I'm hoping I can accomplish what I need if I can load that front compartment really well.
2019 Chevy RST Silverado 1500
1954 Chevy 3100 Carryall 4x4
2002 Sandpiper T22
04 FXDL Harley
Boomerweps
Hills of PA
Posted: 03/23/21 10:42am Link  |  Quote  |  Print  |  Notify Moderator
Get larger propane tanks if you have only the 20# units. You can get 30 & 40# ones
Add a second battery.
Replace manual tongue jack with a power jack.
Those are useful additions that cost a little $$. Next are FREE.
Carry a load of freshwater. Clean water tank is usually in front of the axles.
Put your spare tire in the forward storage if it fits.
2019 Wolf Pup 16 BHS Limited, axle flipped
2019 F150 4x4 SCrew SB STX 5.0 3.55 factory tow package, 7000#GVWR, 1990 CC Tow mirrors, TBC
Posted: 03/23/21 11:13am Link  |  Quote  |  Print  |  Notify Moderator
LOL, you're assuming the OP just bought the trailer (maybe I missed that) and you're assuming that whomever sold him a now 19 year old trailer actually gives 2 ___ks about how it tows. Private party or dealer.
Just add some weight up front. Make it dead weight if can't figure out useful weight (like extra batteries, etc).
Could go to a scrap yard, get some thick steel bar or plate. That's the best bang for the buck save for solid lead. I just scrapped about 400lf of 2" x 4" steel bar. would have been great. Quick calc is 27lbs/lf.
2017 Heartland Torque T29
BenK
SF BayArea
Posted: 03/23/21 06:54pm Link  |  Quote  |  Print  |  Notify Moderator
Ops...correction = 6”-8” behind the CG of the trailer...
mkirsch
Rochester, NY
Posted: 03/24/21 08:53am Link  |  Quote  |  Print  |  Notify Moderator
This would require significant modification to the trailer. The wheel wells and openings would have to be relocated along with the axles. That's assuming there is no structure, plumbing, wiring, facility, or appliance already occupying the space where the wells would need to be moved.
Hardly something I would want to do to a new trailer, or a 19 year old trailer. I think I'd set fire to a poorly-towing 19 year old trailer and watch it burn to the ground before I'd relocate the axles.
campigloo
Baton Rouge, La
Posted: 03/25/21 01:56pm Link  |  Quote  |  Print  |  Notify Moderator
Maybe you could mount a nice tool box on the front of the trailer; over the tanks? Move the spare to an under trailer rack. Are your wd bars properly adjusted, maybe back off a link?
Would like to hear what you did if you find something that works!
Jarlaxle
New England
Posted: 03/27/21 03:01pm Link  |  Quote  |  Print  |  Notify Moderator
OP already stated the fresh water is behind the axle-that's one reason for his problem.
John and Elizabeth (Liz), with Briza the size XL tabby
St. Bernard Marm, cats Vierna and Maya...RIP. ">
Current rig:
1992 International Genesis school bus conversion
