RV.Net Open Roads Forum: Travel Trailers: Which of these two trailers tows better
 > Which of these two trailers tows better
speediq99
Arizona
Posted: 03/20/21 02:37pm Link  |  Quote  |  Print  |  Notify Moderator
Gdetrailer,
What is involved in setting up the landscape 15g tank. Is this something that can be seemlessly integrated or so you have to stop and pump?
I don't know that they make additional or larger replacement tanks for the 2021 F150 Hybrid yet or at least I have not found it.
Mike
Gdetrailer
PA
Posted: 03/20/21 02:40pm Link  |  Quote  |  Print  |  Notify Moderator
speediq99 wrote:
The only caveat with the Hybrid is the gas tank. They lightly mention that even with the Max tow package, it 8s only a 30g tank.
I puzzles me as to why they leave out the tow mirrors with this package.
Many people do not want or like the larger tow mirrors and the added cost.
Had to replace a power scope (power extend and power fold) mirror on our 2013 F250, the Ford OEM replacement mirror cost $1400 and that was with a discount.
Yet another reason why in reality there is not as much price advantage to buying a F150 instead of a F250.. F250, you get towing mirrors by default.
And yes, love the large extendable towing mirrors..
LVJJJ
NW WASHINGTON
Posted: 03/20/21 07:56pm Link  |  Quote  |  Print  |  Notify Moderator
rexlion wrote:
In terms of fuel economy, it's pretty much a wash. In terms of handling, I would expect the shorter TT to behave better due to less tail to wag the dog.
Nope, longer the trailer the easier it is to tow with less sway. Had both long and short, know what I'm talking about after 33 years of towing experience.
1994 GMC Suburban K1500
2005 Trail Cruiser TC26QBC
1965 CHEVY VAN, 292 "Big Block 6" (will still tow)
2008 HHR
L(Larry)V(Vicki)J(Jennifer)J(Jesse)J(Jason)
LVJJJ
NW WASHINGTON
Posted: 03/20/21 07:57pm Link  |  Quote  |  Print  |  Notify Moderator
Nope, long trailer less sway, easier, short trailer whip back and forth.
Gdetrailer
PA
Posted: 03/20/21 09:21pm Link  |  Quote  |  Print  |  Notify Moderator
speediq99 wrote:
Gdetrailer,
Mike
Missed your question..
The tank I have is designed to be a gravity flow but since it sits in the bed, gravity doesn't work.. So, I added a aftermarket feul pump rated for gas to it. Since you don't really want to mess with the emissions system I decided to just use the hose and nozzle that came with the tank..
Basically at one of my rest stops when the main tank is low enough to I will transfer the fuel from the landscaper tank. Takes about 10 minutes to transfer 15 gallons.
I was lucky to buy mine after the manufacturer discontinued it for $100, there is a different brand now but the cost is now $180..
Tank looks like this..
Found HERE
Mounted mine to a couple of 2x6 boards and then bolted that to the bed.. Added a aftermarket auto electric fuel pump and a filter and away we go..
It is actually tough to find gas rated aux fuel tanks and there may be still a aftermarket tank builder that makes larger replacement tanks for trucks but the last time I looked at that option it was something on the order of $1K plus installation.. Can't think of the manufacturer name right now.. Used to see posts about them on FTE (Ford Truck Enthusiasts) forum.
