RV.Net Open Roads Forum: Technology Corner: Small wireless laser printer/scanner/copier
 > Small wireless laser printer/scanner/copier
jcpainter
Crossville, TN
Posted: 03/19/21 12:32pm Link  |  Quote  |  Print  |  Notify Moderator
I'm looking for a reasonably small wireless laser printer/scanner/copier. I can't seem to find one that meets all the criteria.
Does anyone know of one that meets ALL of the above criteria?
Thanks
fj12ryder
Platte City, MO
Posted: 03/19/21 02:14pm Link  |  Quote  |  Print  |  Notify Moderator
What are your criteria? Not everyone thinks the same when it comes to size.
Howard and Peggy
"Don't Panic"
Gdetrailer
PA
Posted: 03/19/21 02:30pm Link  |  Quote  |  Print  |  Notify Moderator
HP Laserjet Pro M29W is most likely going to be about the smallest you are going to find that has scanning built in.
Found HERE
From what I am reading it does scan in color, but it is only monochrome (B&W) for printing.
Due to the size, the input paper tray cannot store paper when closed.
Gdetrailer
PA
Posted: 03/19/21 02:35pm Link  |  Quote  |  Print  |  Notify Moderator
Most combination print/scan/fax all in one units seem be built under the assumption that everyone whats a full sized floor standing office copier.. Many of these units now days are way oversized and will not fit on a desk.. The average multi use printer takes up the space of 4 GC2 batteries (two stacks of two) and that would be on the small side.
I don't understand why they have grown, but they have..
HP does have some smaller printer/scanners which is most likely the direction the OP will need to go.
jcpainter
Crossville, TN
Posted: 03/19/21 03:57pm Link  |  Quote  |  Print  |  Notify Moderator
Found HERE
Thank you very much.
Taxman2436
Holden, MA
Posted: 03/19/21 06:11pm Link  |  Quote  |  Print  |  Notify Moderator
Not a laser and Pricey but if you’re going to use it on the road as much as I do it’s worth the price:
https://www.amazon.com/HP-OfficeJet-250-Portable-Wireless/dp/B01HGD8R5S/ref=sr_1_2?dchild=1&keywords=hp+mobile+printer+250+all+in+one&qid=1616198948&sr=8-2
Taxman2436
Holden,MA
2019 Ford F-250 6.7 L Diesel
2021 Salem Hemisphere
bob213
Fresno, CA
Posted: 03/19/21 07:15pm Link  |  Quote  |  Print  |  Notify Moderator
I have the HP LaserJet Pro M29W that Gdetrailer referenced above and am very happy with it. Great output, low cost consumables and it does scan in color but only prints in Black.
ktmrfs
Portland, Oregon
Posted: 03/19/21 09:11pm Link  |  Quote  |  Print  |  Notify Moderator
If size is important I'd look at a ink jet. you'll likely find many more choices.
Even then small size = $$$$$
2011 Keystone Outback 295RE
jcpainter
Crossville, TN
Posted: 03/20/21 03:40am Link  |  Quote  |  Print  |  Notify Moderator
Thank you so much for the review. I appreciate it and will probably order this one.
jcpainter
Crossville, TN
Posted: 03/20/21 03:42am Link  |  Quote  |  Print  |  Notify Moderator
Yes, but we want to keep this in the RV and so often the ink jet cartridges dry out when not used for a while.
