RV.Net Open Roads Forum: Tech Issues: mounting my solar panels
 > mounting my solar panels
1L243
Oregon
Posted: 03/25/21 04:58pm Link  |  Quote  |  Print  |  Notify Moderator
Something to think about when deciding how many bolts/screws to secure your panels to the roof. I was watching a couple of youtube videos on boondocking and one guy was camped in the California desert and a 80+ mph wind/dust storm kicked up for many minutes. It blew his antenna and vent cover off the roof. He did not have solar panels on his roof but if he did I thing they would have been gone.
Another video a couple heads off into the National Forest and comes across a washboard portion of the dirt road. It was enough to rattle your filling out.
If you not planning on going off paved roads it may not be that big of a deal. Although several years ago I was heading across New Mexico and a freak windstorm came up. We got off the freeway and found a nice protected RV Park. We got blown around pretty good. Later we learned that they closed the freeway and several big rigs were blown over.
Kinda make me glad that I put the extra screws in my panels...
2017 Coleman 300tq by Dutchman Toy Hauler. 34.5 feet long and under 10k Gross. 500 watt Solar 2000 watt Inverter, 1999 Ford F250 2WD 7.3 4R100 DP Tuner, S&B Cold Air Intake, Gauges, 6.0 Trans Cooler, Air Bags.
Shadow Catcher
NW Ohio
Posted: 03/26/21 02:52pm Link  |  Quote  |  Print  |  Notify Moderator
Ed_Gee wrote:
3M double sided VHS tape, No. 4950, is probably holding many thousands of solar panels on RV roofs for years - and not a single report of one ever not working. The best leak seal of all is no seal needed.
Ours has been up for 12 years, however you have to have enough surface area and do proper surface prep. Wind loads in excess of 120MPH
lane hog
Tucson, AZ & NW Chicago Burbs, IL
Posted: 04/03/21 07:46am Link  |  Quote  |  Print  |  Notify Moderator
Hope it went well. I was lucky on our roof that I could see and measure the structural members from the inside after removing the vent shrouds. No question that I'm in a rafter vs. just the roof.
  • 2019 Grand Design 29TBS (had a Winnebago and 3x Jayco owner)
  • 2016 F-150 3.5L MaxTow (had Ram 2500 CTD, Dodge Durango)
  • 130W solar and 2005 Honda EU2000i twins that just won't quit
Darklock
Georgia
Posted: 04/05/21 06:43am Link  |  Quote  |  Print  |  Notify Moderator
I have not mounted them yet. Wash the roof and by the time it dries, it is covered with pollen again. I will wait till after the pollen is done falling. I hate the pollen around here. Everything is yellow.
Almot
out there
Posted: 04/05/21 02:14pm Link  |  Quote  |  Print  |  Notify Moderator
I would not trust any adhesive to hold solar panel to rubber-ish coated plywood. This membrane is thin and in some places doesn't adhere to the plywood if you look close. It has very little strength on its own, its only purpose is to protect the plywood from water ingress. If solar panel starts moving it will rip a piece of membrane off the roof.
You already have dozens of screws in that plywood, another dozen won't make it worse. Use #10 stainless sheet metal screws, with Dicor sealant under the brackets as described. There are different kinds of Dicor, you want this one: https://www.amazon.com/gp/product/B004A2........_yo_dt_b_search_asin_title?ie=UTF8&psc=1. Put a generous coat of Dicor under the bracket so that it would ooze from under the bracket edges when you put the screws in. Lubricate screw with Dicor, drive it in, cover the screw head with Dicor. You don't have to cover the entire plate.
lane hog
Posted: 04/06/21 04:44am Link  |  Quote  |  Print  |  Notify Moderator
Do you have a solar prep for the wiring? If not, what's your plan?
Darklock
Georgia
Posted: 04/06/21 06:58am Link  |  Quote  |  Print  |  Notify Moderator
I am using well nuts to hold down the panels. The reason I am waiting on pollen is for the eternabond tape that will hold down the cables. I realize that a little pollen probably will not matter for these, but why not wait. I am not in any hurry, and I wrenched my back two weeks ago and am waiting for it to get better.
As for the wiring.... I plan on running the wires down the the roof near the shower vent. From there under the kitchen sink, behind the fridge and come out to the controller that is mounted at the end of the cabinet. Wires from battery to controller run along bottom of trailer and come through floor behind fridge, then up to controller. This allows me to not have any of the cables visible.
Freep
Wisconsin
Posted: 04/06/21 01:40pm Link  |  Quote  |  Print  |  Notify Moderator
I know you already got the panels but you will likely need more. I have 600 watts of panels(4x150) on my truck camper and I'm thinking about adding another 300.
When picking solar panels for your rig figure out how much space you can use, then pick panels of the largest dimension you can fit in the space with the highest density of wattage per square foot. Those panels will last 20 years, don't go cheap.
2014 Lance 992
2014 Ram 3500 DRW Turbo diesel
lane hog
Posted: 04/06/21 10:57pm Link  |  Quote  |  Print  |  Notify Moderator
Keep in mind everyone has their own power footprint...
Someone who only needs minimal recharging to cover their fridge and some phone charging might be just fine with 100-200W of cheap panels from Harbor Freight and a pair of lead acid batteries.
If you're trying to power a residential fridge and keep two laptops and a big screen TV running 12 hours a day, that 900W roof of Freep's might be justified along with a bank of $1000 batteries.
Before spending the big bucks, figure out your amp hours and plan accordingly.
Darklock
Georgia
Posted: 04/08/21 06:15am Link  |  Quote  |  Print  |  Notify Moderator
AS mentioned earlier, my need is small. Water pump, a few led lights, cell phone charging and whatever the fridge needs while running on LP. I have installed a DC-DC charger to charge battery while driving, and have a generator to use if really needed. I think I am good with 200W.
