RV.Net Open Roads Forum: Tech Issues: mounting my solar panels
 > mounting my solar panels
1L243
Oregon
Posted: 04/17/21 10:30pm Link  |  Quote  |  Print  |  Notify Moderator
Not to hijack my own thread but was scanning through some RV solar panel mounting projects and notice how much difference there was in the distance between the panels and the roof of the RV. In my case I used Renogy two piece mounting brackets and was limited on the height of the panel.
My roof is curved, the ends of the panels are 3" from the roof the center of the panel is 2 1/2" from the roof.
I read that to allow fro proper panel cooling 3" minimum but 4" to 6" would be ideal.
I was wondering what the consensus would be on panel height?
2017 Coleman 300tq by Dutchman Toy Hauler. 34.5 feet long and under 10k Gross. 500 watt Solar 2000 watt Inverter, 1999 Ford F250 2WD 7.3 4R100 DP Tuner, S&B Cold Air Intake, Gauges, 6.0 Trans Cooler, Air Bags.
SJ-Chris
San Jose, Ca
Posted: 04/18/21 06:04pm Link  |  Quote  |  Print  |  Notify Moderator
I'm far from an expert, but... I think most Z-brackets only provide about 1 inch of spacing between the panel and the roof. I'm guessing it is fine. If you've got 2" or 2.5" that seems like more than enough.
-Chris
San Jose, CA
Own two 2015 Thor Majestic 28a Class C RVs
TechWriter
On The Road
Posted: 04/18/21 07:25pm Link  |  Quote  |  Print  |  Notify Moderator
I used two aluminum rails and four L-brackets to mount each of my panels.
2001 Newmar Mountain Aire 4095 DP
Part Timer 2004 - 2013
Full Timer 2013 - 2020
Part Timing Again
www.rvSeniorMoments.com
DISH TV for RVs
lane hog
Tucson, AZ & NW Chicago Burbs, IL
Posted: 04/22/21 02:22am Link  |  Quote  |  Print  |  Notify Moderator
Mine have maybe 2" underneath and none of the three RV's they've been installed on have caught fire yet...
  • 2019 Grand Design 29TBS (had a Winnebago and 3x Jayco owner)
  • 2016 F-150 3.5L MaxTow (had Ram 2500 CTD, Dodge Durango)
  • 130W solar and 2005 Honda EU2000i twins that just won't quit
