RV.Net Open Roads Forum: Tech Issues: Ground wires
 > Ground wires
dougrainer
Carrolton, Texas
Posted: 03/21/21 08:00am Link  |  Quote  |  Print  |  Notify Moderator
Since this bothers you and I guess you want to tinker and make it better. I would take each white Ground wire, install a ring terminal, solder after crimping and drill a hole thru the frame and use star washers and secure a few wires to each new bolt stud. 15 wires, I would install 5 bolts and install 3 wire ring terminals on each new stud bolt. THEN undercoat each stud. never have to worry about looseness or corrosion. Doug
YES, That is how Jayco runs their 12 volt ground wires.
 > Ground wires
