RV.Net Open Roads Forum: Tech Issues: Gray water
 > Gray water
Weldon
Posted: 03/21/21 11:12am Link  |  Quote  |  Print  |  Notify Moderator
Gray water from shower and bath lavatory. Can this tank leak if the tank is overfilled?
Ed_Gee
Central Oregon coast
Posted: 03/21/21 11:30am Link  |  Quote  |  Print  |  Notify Moderator
In my experience an overfull grey tank will just back up into the shower drain....
Ed - on the Central Oregon coast
2018 Winnebago Fuse 23A
Scion xA toad
Old-Biscuit
Verde Valley
Posted: 03/21/21 11:42am Link  |  Quote  |  Print  |  Notify Moderator
YES it can leak
Drains from sink/shower go into top of tank as does the vent pipe
Some RV MFGs glue the pipes to tank fittings
Some RV MFGs use 'grommets' that the pipes slip thru......this type allows for slight movement of tank/pipe but can leak if tank is overfilled
Shower is typically the lowest point so when trank is overfilled it should backup into shower pan.
But that also requires tank level to be high and if grommet is leaking water would come out from there
Also there is the possibility of tank crack
US NAVY------USS Decatur DDG31
jdc1
Rescue, Ca
Posted: 03/21/21 11:52am Link  |  Quote  |  Print  |  Notify Moderator
True.
Anza-Borrego Desert SP area
Posted: 03/21/21 12:54pm Link  |  Quote  |  Print  |  Notify Moderator
X2, Ed Gee
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, WindyNation 300 watt solar-Lossigy 200 AMP Lithium battery. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
Weldon
Posted: 03/21/21 02:20pm Link  |  Quote  |  Print  |  Notify Moderator
No water in shower, noticed a leak near the handle you pull to drain tank. Had been camped for 3 days. Bottom is enclosed so could not see at the time. Seem to stop within minutes after tank was drained. After our recent snow and freezing temps here in Texas there were no leaks when water supply was turned on and no sound from a water leak. But maybe it had to soak thru insulation before leaking?
Thanks for the comments!
BB_TX
McKinney, Texas
Posted: 03/21/21 02:54pm Link  |  Quote  |  Print  |  Notify Moderator
Only way to know for sure is to open the belly and watch. There have been reports of leaks around fittings and leaks due to cracks. Whatever, it shouldn’t leak.
LouLawrence
Traveling the US!
Posted: 03/22/21 06:17am Link  |  Quote  |  Print  |  Notify Moderator
Old-Biscuit wrote:
YES it can leak
This is also quite true. Depending upon the connections to the vent and the drain at the top of the tank, it could easily cause a leak if the connections are loose. I had a similar issue in my past coach and finally just learned to live with it and ensured I never overfilled the gray.
schlep1967
Harrisburg, PA
Posted: 03/22/21 07:13am Link  |  Quote  |  Print  |  Notify Moderator
Question: Is the drain handle pretty easy to pull to open/push to close? There are four bolts around the gate valve. These apply pressure to keep the o-rings from leaking. I've noticed that if those bolts get loose the gate valve slides easier.
Either way the first thing I would do is open up the belly so I could check the valve area for your leak. If the leak is there it may be as simple as snugging up the bolts. Or maybe replacing the o-ring.
2008 Dodge Ram 2500 Diesel
2009 Open Range 385RLS
Pull-Rite Super Glide
naturist
Lynchburg, VA
Posted: 03/22/21 11:06am Link  |  Quote  |  Print  |  Notify Moderator
Does it contain water? Then it can leak.
 > Gray water
