RV.Net Open Roads Forum: Travel Trailers: Sharp reverse turn with Equl-i-zer hitch?
 > Sharp reverse turn with Equl-i-zer hitch?
wopachop
Who run bartertown
Posted: 03/22/21 08:56pm Link  |  Quote  |  Print  |  Notify Moderator
Once parked will you relieve tension on the bars? If that's the case I would use the electric jack to lift the tongue enough to slide the bars off the brackets.
I do that to my trailer when I get to the neighborhood. Cant be more than 30 seconds.
LVJJJ
NW WASHINGTON
Posted: 03/24/21 08:05am Link  |  Quote  |  Print  |  Notify Moderator
I think I'd remove the EQ bars before making that manuver. I've had to take the bars off only twice backing in. Once when backing into an uphill camp site, the bars took so much weight off the rear tires of the TV that it lost traction part way up. Had to roll back down and remove bars first. The other problem is not being able to disconnect one of the bars when the TV is tipped at an angle from the TT. Simply cannot get the downhill side bar off the "L" bracket. Finally disconnected chains, electrical & emergency brake and raised TT off of ball and pulled forward, bar came off with a loud bang. Nothing hurt.
1994 GMC Suburban K1500
2005 Trail Cruiser TC26QBC
1965 CHEVY VAN, 292 "Big Block 6" (will still tow)
2008 HHR
L(Larry)V(Vicki)J(Jennifer)J(Jesse)J(Jason)
Kavoom
Kansas
Posted: 03/24/21 08:08am Link  |  Quote  |  Print  |  Notify Moderator
"I too need to make a sharp turn and at an angle when backing my TT at the house. I simply remove the WD bars and do what I need to do."
I have the same issue with a sharp turn into the driveway. I have a great pull through place to pull the bars off about a mile from home and do so... Then No Problem.
JIMNLIN
Oklahoma
Posted: 03/24/21 08:39am Link  |  Quote  |  Print  |  Notify Moderator
I have a Husky Centerline TS with 1200 lb bars for a 10k car hauler. I use the trailer to carry my blue tractor in and around muddy construction work sites and off road in and around farm/ranch pastures. Lots of sharp backing/going forward with truck off angle to the trailer and never a issue.
The trailer has 8860 or 9420 lbs on the axles depending on tractor implements and where the load is placed on the trailers deck.
The Husky Centerline TS looks like and works like the Equalizer brand other than the Husky is a round bar hitch that flattens at one end.
MikeDupont
TX
Posted: 03/24/21 03:58pm Link  |  Quote  |  Print  |  Notify Moderator
Wow, all these years with a Equalizer and i didnt realize i had a problem until now. Maybe i dont back up at what you all are referring to as a 'sharp' angle.
lane hog
Tucson, AZ & NW Chicago Burbs, IL
Posted: 04/01/21 06:48am Link  |  Quote  |  Print  |  Notify Moderator
I do a 90* backup turn into my driveway off a state highway, and never remove the bars on my DC...
  • 2019 Grand Design 29TBS (had a Winnebago and 3x Jayco owner)
  • 2016 F-150 3.5L MaxTow (had Ram 2500 CTD, Dodge Durango)
  • 130W solar and 2005 Honda EU2000i twins that just won't quit
RHasse
So Cal
Posted: 04/01/21 06:02pm Link  |  Quote  |  Print  |  Notify Moderator
Same here...
Lynnmor
Red Lion
Posted: 04/02/21 06:59am Link  |  Quote  |  Print  |  Notify Moderator
You need an Oldsmobile Tornado.
'tiredTeacher
Richmond, VA
Posted: 04/06/21 02:40pm Link  |  Quote  |  Print  |  Notify Moderator
I'm no trying to be a smart ass. I've just noticed folks look at backing as a separate maneuver from driving forward. Isn't it the same path for the wheels? Do you remove (or not install) the bars when pulling out of the driveway? How is pulling out different from backing in?
Teach
Wright and Penny
2010 Tundra 4X4
2014 Rockwood 2604WS
"Life is a cruel teacher. She gives the test first; the lesson then follows."
'tiredTeacher
Richmond, VA
Posted: 04/06/21 02:43pm Link  |  Quote  |  Print  |  Notify Moderator
I'm old enough to have seen that commercial on TV and it was a Toronado.
