RV.Net Open Roads Forum: Tech Issues: Solar Questions
 > Solar Questions
1L243
Oregon
Posted: 03/22/21 10:26pm Link  |  Quote  |  Print  |  Notify Moderator
I have completed my 500 watt solar install with 2000 watt PSW Inverter. I have a couple of questions.
If your plugged into shore power at a Park would you
Question:
1. Have both the Converter and Solar Charge Controller maintain batteries at same time?
2. Solar Charge Controller only with Converter breaker off?
3. Shut down Solar completely and let Converter maintain batteries?
Question:
When I turn on my Inverter it will energize all the outlets in my RV. I will have The AC breaker off, Hot water heater is on propane as is the refrigerator BUT I will have 3 tv's a 40" and two 24", a satellite box and a portable satellite dish. None of these will be on but will be plugged in.
Do these devices need to be unplugged before turning on Inverter.
Question:
Do you clean your solar panels, if so what do you use?
2017 Coleman 300tq by Dutchman Toy Hauler. 34.5 feet long and under 10k Gross. 500 watt Solar 2000 watt Inverter, 1999 Ford F250 2WD 7.3 4R100 DP Tuner, S&B Cold Air Intake, Gauges, 6.0 Trans Cooler, Air Bags.
CA Traveler
The Western States
Posted: 03/22/21 11:02pm Link  |  Quote  |  Print  |  Notify Moderator
#3 Batteries are maintained 24/7.
No need to unplug when turning on the inverter. Although off they may be on standby and using some power while the inverter is on.
Clean panels with soap and water or just wait for the next rain, I generally wait.
Normally A/C, HW and refer are not on the inverter output because they use a lot of power. A residential refer with a larger battery bank would be on the inverter.
2014 Grand Cherokee Overland
Bob
pianotuna
Regina, SK, Canada
Posted: 03/22/21 11:06pm Link  |  Quote  |  Print  |  Notify Moderator
Hi 1L243,
My solar and all forms of charging play well together. So I would go with #1.
My preference is to shut everything down when I switch to using the inverter. The transfer switch I have is internal to the inverter/charger and I'd hate to burn the contacts, so switching at zero load is best. Items don't need to be unplugged--but I do switch them off, other than the microwave clock. My default for the converter is unplugged.
I use dawn dish soap sparingly with lots of water and a soft microfiber cloth. Mostly I don't clean them at all.
Regards, Don
BFL13
Victoria, BC
Posted: 03/22/21 11:14pm Link  |  Quote  |  Print  |  Notify Moderator
If you can set the solar at constant 13.x volts same as the converter's float then leave all on, but if the solar does some 14.x first then drops to 13.x, then turn it off and just use the converter.
I turn my solar off at home because I can't stop the controller from going to 14.X first.
I have my TV on a power bar with its own on/off switch because the TV "off" is standby still drawing amps. I have not had any trouble turning the inverter on with a TV load, but as with a gen you should turn the inverter on first, certainly with a big load. I turn the inverter on as soon as shore power is off and the inverter stays on till we get home again. I don't bother with the small draw leaving it on-- With solar the inverter draw is trivial.
I clean the panels fairly often. The worst is seagull poop--big splatters. Mostly it is morning dew on the dust which makes them sort of muddy all over. Depends where you are how bad they get. Helps to be spry to get up there. [emoticon]
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
corvettekent
Marysville, WA
Posted: 03/22/21 11:18pm Link  |  Quote  |  Print  |  Notify Moderator
I unplugged my converter seven years ago. My solar keeps my batteries charged.
You can leave stuff plugged in when you power on your inverter. Your satellite dish will need to reboot after you turn the inverter on.
I clean my panels with soap and water a couple times a year.
2007.5 GMC Dually EC/LB, LMM. Banks IQ, Speed Brake, Six Gun. B&W Turnover Ball, Companion Hitch, Amp power steps. Hadley Air horns.
2004 32' Carriage 5th wheel. 860 watts of solar MPPT and four 6 volt batteries. Samlex 2,000 watt Pure Sine Wave Inverter.
1L243
Oregon
The way my system is setup I plug the shore power into the inverter BUT first I turn of the breaker at the Converter that controls charging the batteries. I also throw the breaker for the AC just so it don't come on automatically. I have to unplug my refrigerator to force it to gas otherwise it chooses electric for you if it's plugged into 110. My Hot water heater is propane only so not part of the loop.
Good to know about cleansing the panels I really don't want to have to go up on the roof all the time to keep them clean.
pianotuna
Regina, SK, Canada
Posted: 03/22/21 11:21pm Link  |  Quote  |  Print  |  Notify Moderator
Hi 1L243,
If they are LiFePo4 batteries they won't "love" being float charged. So that case I'd have a different answer.
1L243
Oregon
Posted: 03/22/21 11:26pm Link  |  Quote  |  Print  |  Notify Moderator
pianotuna wrote:
Hi 1L243,
No, unfortunately not. Four 12v lead acid 340ahs.
StirCrazy
Kamloops, BC, Canada
Posted: 03/23/21 09:00am Link  |  Quote  |  Print  |  Notify Moderator
Question:
Question:
Question:
I have almost this exact configuration on my 5th wheel 480 watts of solar. just treat it like the solar isnt there, let all sources charge the battery they wont over charge unless your converter is a old one with out three stage charging.
your tv's will have a parasitic draw so its up to you if that is to much. I dont ever turn my ac breaker off as I have my inverter on a transfer switch so it still feeds the rv from the AC breaker , if your inverter power the intire trailer like mine you are proabably in a simular set up and turning off your ac breaker will defete the purpose of having the inverter. and yes I clean my pannels at the begining of eevery season. I do it very early in the morning or after it gets dark so they are not hot and I just use water and dishwashing soap. wipe them with a rage and the soapy water then rince them off.
Steve
2014 F350 6.7 Platinum
2016 Cougar 330RBK
pianotuna
Regina, SK, Canada
Posted: 03/23/21 09:32am Link  |  Quote  |  Print  |  Notify Moderator
1L243 wrote:
pianotuna wrote:
Hi 1L243,
I'm not an li fan. So I see your situation as fortunate.
 > Solar Questions
