RV.Net Open Roads Forum: Tow Vehicles: Bed liner - spray in
Search only in Tow Vehicles
 > Bed liner - spray in
Posted: 03/23/21 07:03pm Link  |  Quote  |  Print  |  Notify Moderator
^Neither of them will hold up 100% to true daily hard use. But neither will the truck bed itself, it will be more banged up/dented/scratched without the liner.
Linex will last much longer than Rhino if running forks/pallets, sharp objects in and out of the bed.
Honestly the best protection for the bed itself under heavy use is a plastic drop in bed liner.
2017 Heartland Torque T29
monkey44
Cape Cod, MA and Central Fla
Posted: 03/23/21 08:52pm Link  |  Quote  |  Print  |  Notify Moderator
Well, I'm mostly retired, but need my truck to haul things occasionally - I don't abuse trucks anymore, like when I was building homes ... but sometimes it get a scratch or two, and I figured I'd spray it, and still use the bed mat for the camper.
Might leave the bed mat in for slip resistance, and replace it if it gets damaged - but the spray in is to UN-scratch my bed walls. They're in fairly good shape, and want to keep them that way.
Looks like Line-X it is ... most favor it. Thanks for the info... M 44
Monkey44
Cape Cod Ma & Central Fla
Chevy 2500HD 4x4 DC-SB
2008 Lance 845
Back-country camping fanatic
blt2ski
Kirkland, Wa
Posted: 03/23/21 09:09pm Link  |  Quote  |  Print  |  Notify Moderator
Grit,
I've had bed liners too. I'd still take a spray in vs a drop in. Both can have the bed itself get dented etc. Especially if you drop some 50-100+ lb objects in the bed. Be them rocks, concrete wall blocks, larger logs etc.
Issue I found the liners, is soil, bark, etc can get between the bed and liner, liner moving, the paint grinds away etc between the two.
Reality, which is worst? Not sure. The spray in being reasonably non skid, vs liner very little. Access to ALL the internal bed tie downs etc. The spray is better in the end.
My 02
Marty
Check RV.Net Blogs at: blog.rv.net
ACZL
UPstate,NY
Posted: 03/24/21 09:01am Link  |  Quote  |  Print  |  Notify Moderator
Have used Line-X in 3 trucks and very happy with how they have held up. Like what's been said about both regarding warranties, I still chose Line-X. 1st truck was a '03 Super Duty, 2nd '15 SD and 3rd is '17 SD. Not sure about Rhino, but with Line-X you can get it in different colors. I don't haul sharp objects so chances of scratching or gouging is low. Yes it is rough on your knees, but I really like tho how it offers protection form everything. Should my future allow me to get another new truck again, I'd go w/ Line-X still.
2017 F350 DRW XLT, CC, 4x4, 6.7
2018 Big Country 3560 SS
"The best part of RVing and Snowmobiling is spending time with family and friends"
"Catin' in the Winter"
Bumpyroad
Virginia
Posted: 03/24/21 02:16pm Link  |  Quote  |  Print  |  Notify Moderator
years back I went with a bed liner for my S-10 PU. at that time there were many reports of the liner vibrating and rubbing the paint off of the bottom of the bed and the mfr. wouldn't warranty that paint so I cut some masonite sheets to cover bottom, used some globs of silicone sealer to hold them in place and then installed the liner over them.
bed looked as good as new when I sold it.
bumpy
s1214
Vt
Posted: 03/25/21 08:12am Link  |  Quote  |  Print  |  Notify Moderator
Up here in our part of the NorthEast, I prefer ONYX Bedliners. I've had one last over 10 years with very little cosmetic damage and no fading.
Hammerboy
Zeeland, MI
Posted: 03/25/21 09:27am Link  |  Quote  |  Print  |  Notify Moderator
I had both Line X and Reflex spray in liners. I like the Reflex as its more grippy therefor keeps stuff from sliding around. Both are very durable.
Dan
2019 Chevy crew LTZ 2500 HD Duramax
2017 Wildcat 29rlx fifth wheel
