RV.Net Open Roads Forum: Class A Motorhomes: Toilet seal lube?
two travelers
Smithtown, NY
Posted: 03/23/21 11:14am Link  |  Quote  |  Print  |  Notify Moderator
We have a Dometic 310 series porcelan toilet about 2 yrs old. Checking toilet after the winter, seems that the seal is not sealing properly and the water leaks out over time. What can I use to "lube" it up? Silicone? I'm also going out to clean the seal again.
Monterey, California
Posted: 03/23/21 11:20am Link  |  Quote  |  Print  |  Notify Moderator
I use silicone.
Ed C
Cape Cod, MA
Posted: 03/23/21 11:39am Link  |  Quote  |  Print  |  Notify Moderator
Years ago a parts guy at Camping World told me regular Vaseline was the best. It has worked well for me on a few occasions.
Ed/Jeanie & Slade the GSD
2017 Entegra Aspire 42 RBQ/ Sierra Crew
bob213
Fresno, CA
Posted: 03/23/21 12:03pm Link  |  Quote  |  Print  |  Notify Moderator
Vaseline is a petroleum product. NO petroleum product should be used on the seal. Try Plumbers Silicone lube or just plain olive oil.
TenOC
On the road -- Full time
Posted: 03/23/21 01:08pm Link  |  Quote  |  Print  |  Notify Moderator
Has anyone tried this
Please give me enough troubles, uncertainty, problems, obstacles and STRESS so that I do not become arrogant, proud, and smug in my own abilities, and enough blessings and good times that I realize that someone else is in charge of my life.
Travel Photos
morley
British Columbia
Posted: 03/23/21 02:55pm Link  |  Quote  |  Print  |  Notify Moderator
Go to any regular hardware, Lowes or the such and buy something called Plumbers Grease. It is a little packet and costs less than $10.00 here. Apply it to the toilet seal liberally and it should work fine. We had a seal that didn’t work, so we applied the lube and kept that little bit of water in the bowl that you need to keep the seal moist and it held good all last season, will make this a regular part of each seasons startup.
2008 Topaz F254SS 26 ft.
2009 Chevy Silverado, 2500HD, Duramax, Allison Tranny, 4x4, EC
250 watt solar panel system, BlueSky controller and remote
ernie1
Sacramento,California,USA
Posted: 03/23/21 05:25pm Link  |  Quote  |  Print  |  Notify Moderator
Be careful when purchasing "Plumbers Grease or Lubricant". Not all of them are silicone based.
Posted: 03/23/21 05:54pm Link  |  Quote  |  Print  |  Notify Moderator
2x, Ernie.
rskrbina
NW Missouri
Posted: 03/23/21 07:32pm Link  |  Quote  |  Print  |  Notify Moderator
I've used silicone grease. No leaky seal since.
Rudy, Jenny and Garrett
2014 Thor.. Four Winds 35SK Super C..F-550..6.7 Diesel
CRV, F-150 & Wrangler Sahara Toads..TST Tire monitor
PastorCharlie
NC
Posted: 03/23/21 07:44pm Link  |  Quote  |  Print  |  Notify Moderator
Do a search for "Dometic 310 series porcelain toilet seal replacement" and there are several options for replacement seals.
