RV.Net Open Roads Forum: Truck Campers: tool for dicor removal
 > tool for dicor removal
notsobigjoe
southeast
Posted: 03/25/21 04:16pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for all the tips! I am doing pretty much the whole camper, sides, rear, front and roof. I have always used Dicor and Dicor self leveling on the roof. I had to caulk the slide out room and surrounding area when I bought it because of the water intrusion. Pretty speedy and very lousy job that was in 2009... It looks bad and it's cracked all over he place. I just repaired my leaky slide out room and decide it was time to spruce thing up. I am going for the new gun as well as trying the OSI max.
d3500ram
Colorado
Posted: 03/25/21 05:26pm Link  |  Quote  |  Print  |  Notify Moderator
@OP... just to clarify, I used the OSI on the walls, I would recommend still using the Dicor self-leveling for the roof... it will save a bunch of time because gravity will be your friend.
This was my last sealing job before I sold the camper using Dicor on the roof:
Before:
After:
notsobigjoe
southeast
Posted: 03/25/21 06:02pm Link  |  Quote  |  Print  |  Notify Moderator
Yep, I will do that.
Kayteg1
California > Nevada
Posted: 03/25/21 07:38pm Link  |  Quote  |  Print  |  Notify Moderator
Per my experience all caulking, including Dicor will not last when you don't have sealing butyl tape properly applied.
Caulk is more for cosmetics in RV applications.
mellow
Salisbury, MD
Posted: 03/26/21 09:11am Link  |  Quote  |  Print  |  Notify Moderator
I will be tackling mine here shortly. I bought a pneumatic caulk gun to try out this time. The last camper I resealed I used OSI but this time I will be going back to Proflex in white. I was not to crazy about the clear OSI once I finished.
2002 F-350 7.3 Lariat 4x4 DRW ZF6
2008 Lance 1191 - 220w of solar - Bring on the sun!
markchengr
Seattle
Posted: 03/26/21 09:12am Link  |  Quote  |  Print  |  Notify Moderator
Lately, I've been using white Gorilla tape. It only lasts one year but it's sooo easy. Just peel off the old tape, wipe with the solvent of your choice and reapply.
notsobigjoe
southeast
Posted: 03/26/21 09:38am Link  |  Quote  |  Print  |  Notify Moderator
Butyl will be checked everywhere and I have a bunch on hand. I read the OSI description and I'll try it. I can always go back to Dicor. I have been thinking about using the Eterna bond tape on all roof fittings. I've never done this but the finished product looks awesome. I also think while I'm at it on the roof I'll replace that old bathroom fan with a nice one as well as the shower light globe on top. I don't know what it's called. I'm gonna take my time an all summer project and do it correctly. Goin to Flagler tonight to sit and have adult beverages. This forum is well versed in the RV maintenance world.
mellow
Salisbury, MD
Posted: 03/26/21 10:44am Link  |  Quote  |  Print  |  Notify Moderator
How many tubes did you guys buy to redo the vertical surfaces on your camper? I also have a slideout so that will eat some. I can't remember how many I bought when I redid my last camper but I got them at lowes so it was no big deal. I have to order proflex as the closest dealer that carries it is an hour away. Thanks!
I have 3 10oz on hand at the moment.
Kayteg1
California > Nevada
Posted: 03/26/21 11:53am Link  |  Quote  |  Print  |  Notify Moderator
On my Fleetwood I had rubber roof, who had some damages and age as well.
I tired all kind of expensive coulks on it and none of them really hold.
PO put eternabond on some damages, what in result channeled water on camper frame.
Finally after struggling with it for few years, I found new technology Henry Tropicool roof sealer at Home Depot. That stuff sticks to everything and HOLDS.
I used it on my house flat roof before going to camper.
The sealer will not fill heavy gaps, but 2nd application did the trick.
It is self-leveling, so hard to apply on sloping nose.
deltabravo
Spokane, WA
Posted: 03/26/21 10:36pm Link  |  Quote  |  Print  |  Notify Moderator
notsobigjoe wrote:
Do you smooth out the sealant like you do in a house with a wet finger?
Self leveling Dicor does not need touched with anything after you shoot it out of the calking gun.
Here's a video showing it "self level"
2018 Timber Ridge 24RLS (bought pre-owned 3/12/20)
