RV.Net Open Roads Forum: Towing: Cargo Rating
Search only in Towing
Open Roads Forum  >  Towing
 > Cargo Rating
Gene K 2
Posted: 03/26/21 12:38pm Link  |  Quote  |  Print  |  Notify Moderator
I've wondered if a truck's cargo rating wouldn't be more useful to people shopping for travel trailers than payload. For those unfamiliar Cargo Rating = Payload minus 150 lb per available seating position. For instance a 2,000 lb Payload Regular Cab would have a 1550 lb Cargo Rating and a Bench Seat Crew Cab an 1100 lb Cargo Rating. Seems like it would help people who often think Payload is Cargo Rating (ie how much can I carry in the bed).
Near DVNP, California
Posted: 03/26/21 01:26pm Link  |  Quote  |  Print  |  Notify Moderator
Changing the "system" we have now would be difficult if not impossible IMO. Informed truck buyers are few and far between...and the newbies always want to buy the truck first.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, 300 watt solar-Lossigy 200 AMP Lithium battery. TALL flag pole. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
wing_zealot
East of the Mississippi
Posted: 03/26/21 02:07pm Link  |  Quote  |  Print  |  Notify Moderator
Never heard of Cargo Rating before. I can do the math for myself a lot more accurately than 150 lbs per seat. My truck has 5 seats, 95% of the time only 2 are in use.
The sticker on the door of my truck clearly says "The combined weight of occupants and cargo should never exceed _______". Seems pretty clear to me.
blt2ski
Kirkland, Wa
Posted: 03/26/21 02:12pm Link  |  Quote  |  Print  |  Notify Moderator
How is cargo rating any different than max camper rating in pickups per say....
Then if you have 6 peeps in said crew cab pickup that ave 175-200 per. Your chewing 1200 lbs of people weight vs 900. Yes been there did that done that when I had at the time, spouse, 4 adult sized teens and myself. Reality all I cared about is total payload!
Marty
2014 Chevy 1500 Dual cab 4x4
ssthrd
Vancouver Island
Posted: 03/26/21 02:16pm Link  |  Quote  |  Print  |  Notify Moderator
I always thought that cargo was any item in the truck (people, dog, gravel in the bed, tongue weight, pin weight, whatever) that made up payload. Never knew there was a difference between payload and cargo rating. Too many numbers with too many meanings for most people I think.
To me, the only numbers that mean anything are GVWR, FAWR, RAWR, and GCWR. When weight ratings become a concern for whatever reason, the scale is the only answer.
For a read that includes explanations for all of the acronyms that we commonly run into, check this out from Curt.
2014 Keystone Laredo 292RL
2018 GMC 3500HD 6.5' box SRW Denali Duramax Andersen
DeeBee, JayBee, and Jed the Black Lab
valhalla360
No paticular place.
Posted: 03/26/21 02:25pm Link  |  Quote  |  Print  |  Notify Moderator
I think they have moved away from cargo ratings. I haven't seen it listed last few times we bought. While you could back calculate it, it's more limiting.
Example a family of 4 with a 4 door 6 seat pickup. Assuming a couple of 50lb kids a 200lb husband and 150lb wife, that's 450lb of payload used vs 900lb used by your cargo assumption. You just lost 450lb of usable payload to the assumption working off your cargo rating calculation.
Really unless you are trying to push the truck to the limits, it doesn't make much difference and if you are pushing to the limits, false passenger weights you will never see don't make sense if you need that last 450lb of payload.
If you read the sticker on the door, it's quite clear what is included in payload.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
SweetLou
La Quinta, CA USA
Posted: 03/26/21 03:33pm Link  |  Quote  |  Print  |  Notify Moderator
X2
2013 3500 Cummins 6.7 Quadcab 4x4 3.73 68FE Trans, 2007 HitchHiker Discover America 329 RSB
We love our Westie
Gene K 2
Posted: 03/26/21 03:45pm Link  |  Quote  |  Print  |  Notify Moderator
Cargo Rating is usually what they use for specifying truck campers but as far as I know it's officially a cargo rating.
I've often wondered if something wouldn't work to minimize the misconception that payload was the amount you can put in the bed (without regard to occupant weight). Like anything else that's been tried (like "tow rating" instead of just GCWR and GVWR) it would likely just create more problems.
ssthrd
Vancouver Island
Posted: 03/26/21 06:04pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks Gene...........
Now it makes sense why the payload (3460 lbs) rating on my truck is more than the camper weight rating (2724 lbs). I found the camper info on a sticker in the glove box, and it refers to the cargo weight. Learned something new. 736 lbs difference and a reason why.
valhalla360
No paticular place.
Posted: 03/27/21 06:34am Link  |  Quote  |  Print  |  Notify Moderator
At least with Ford, they list the truck camper rating...not a "cargo rating"
 > Cargo Rating
