Don D.
Tracy, Ca, USA
I have a 2018 Rockwood Geo Pro G19FBS and am unable to get the cable hookup to work with my Furrion TV The signal from the antenna works, but have not figured out how to use the cable hookup. I would appreciate anyone with Rockwood Geo Pro how they operate their TV
2004 Pace Arrow 35G
2001 Dodge Dakota Quadcab
SMI braking
afidel
Cleveland
You're almost certainly running into the antenna booster. There will be a small button to turn it off and a red light that will be on when it's active. Most often it's on the coax plate behind the main tv, but Rockwood has apparently also put them at the secondary tv in the bedroom and under the dinette (why?).
2019 Dutchman Kodiak 293RLSL
2015 GMC 1500 Sierra 4x4 5.3 3.42 full bed
Equalizer 10k WDH
trailernovice
Mission TX
if it's actually the 'cable' hookup (connected from a cable television connection on the utility pedestal to the 'cable in' hookup on the outside of the trailer), it may well be that all modern cable systems have gone to a 'you need a box' system...at a park we use, used to be able to get cable by making that connection....for the past couple of years, it doesn't work because the signal is scrambled and a 'cable box' is the only way to descramble to make the input watchable
Glenn and Toni
2019 Jayco JayFlight SLX8 264 BH
2019 Ram 1500 5.7 3.21 gears
Reese round bar w/d with sway control
BB_TX
McKinney, Texas
Agree with first checking to see if the antenna amplifier is off. Then on the TV menu find where you scan for channels, select cable, and rescan for cable channels.
Near Bishop, California
And sometimes the “box” is more money.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, WindyNation 300 watt solar-Lossigy 200 AMP Lithium battery. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist. 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
Mich upnorth
Niles, MI
On my old trailer the cables were hooked up backwards, might want to check that.
Bob & Barb
2019 F-150 Ecoboost Lariat Crewcab
2014 Coachman Catalina 30RLS
ProPride hitch
falconbrother
North Carolina
We go from camping at dog shows with minimum hookups to full hookups at campgrounds. I have just decided that I always have to set up the booster and the TV for every trip. Otherwise it's as you describe. Try getting channels over the air and make sure that works. Then try the cable. It will require pushing the button on the booster and rescanning under the cable setting on your TV.
1ed
Northern California
Have you checked the source button e remote?
ZINGERLITE
Union Lake, MI
check the cable connections. My Antenna didn't work when i got my trailer. after some swearing I took everything out of the cabinet near the plug, removed the couple screws holding the panel in and go access to the back side of the jack. The spliter had the cable sitting next to it. It wasn't threaded on the spliter. They crank these things out so fast at the manufacture that simple things get missed.
