RV.Net Open Roads Forum: General RVing Issues: Need Generator Help!
 > Need Generator Help!
dcmac214
SW OKLA
Posted: 03/26/21 02:35pm Link  |  Quote  |  Print  |  Notify Moderator
Cummins-Onan Energy Command 30 5.5kW Marquis Gold Gasoline Generator HGJAB
FWIW, this is basically the same generator we had on the 5er and I never had any problems there.
What's the "trick" to refilling the oil?
Very slowly trickled new oil down funnel into dipstick hole, didn't have a full quart in it and it starts spilling all over the place. Generator supposed to take a full 2 quarts.
Very briefly ran it to get the filter filled up, thinking maybe that was the problem. Again slowly trickling oil thru the funnel, it almost immediately started spilling all over the place again.
By trickling I mean trickling - I'm only pouring the oil into the funnel at a rate it doesn't back up in the funnel.
Afterthought: is the trick in the refilling or in the draining? Just struck me that maybe somehow only half the old oil drained out. When I closed the valve it was dripping single drops every 15-20 seconds. And RV is absolutely level.
YWORRYDOG
GRAND RAPIS, MI, USA
Posted: 03/26/21 03:27pm Link  |  Quote  |  Print  |  Notify Moderator
same problem, I get it to the top, the give the starter a burst.
CHUCK and ROSE 2010 Sunseeker
We camp on earth
Lynnmor
Red Lion
Posted: 03/26/21 03:49pm Link  |  Quote  |  Print  |  Notify Moderator
Just a thought, would a turkey baster help? By squirting the oil deep inside, the air can escape beside the baster tube.
PhilipB
MO
Posted: 03/26/21 03:54pm Link  |  Quote  |  Print  |  Notify Moderator
Just did mine and it is slow. Got about 1 1/2 quarts in, then ran it a few minutes and it took the remainder.
On another note, how do you get to the spark plug near the cover on the right. It's really tight. Do they make a special plug wrench?
2015 Ram 2500
2013 Raptor 310TS
azdryheat
Tucson, AZ
Posted: 03/26/21 08:39pm Link  |  Quote  |  Print  |  Notify Moderator
Ironic but I also did my oil today. The first quart and a half went in well enough but I had to slowly fill, stop, let the level go down, add a little more oil and repeat. I had about a quarter of a quart to go and I didn't think it would fit in but it did, little by little.
2013 Chevy 3500HD CC dually
2014 Voltage 3600 toy hauler
2019 RZR 1000XP TRE
Rover_Bill
NE. Ohio
Posted: 03/26/21 10:18pm Link  |  Quote  |  Print  |  Notify Moderator
You might want to try something like THIS syringe to inject the oil deeper into the engine.
kwplot34
home
Posted: 03/28/21 12:11am Link  |  Quote  |  Print  |  Notify Moderator
I use a pump that is used for filling oil in the lower unit on outboard engines works much better than the funnel.
