RV.Net Open Roads Forum: Which E rated ties have the most weight capacity?
Search only in Tow Vehicles
 > Which E rated ties have the most weight capacity?
mrad
Prineton, MN
Posted: 03/27/21 09:28pm Link  |  Quote  |  Print  |  Notify Moderator
I will need to be replacing the tires on my 1 ton. I have noticed there is a bit of a difference in tire weight capacity ratings. I currently have Firestone Transforce that has 3680 lbs per tire. While looking at other tires, I have noticed some have as little as 3200 lbs per tire.
Just curious if there is a tire that has a higher rating than the 3680 lbs??
jdc1
Rescue, Ca
Posted: 03/27/21 10:04pm Link  |  Quote  |  Print  |  Notify Moderator
They'll be within a hundred pounds of each other....or they will be rated higher.
time2roll
Posted: 03/27/21 10:07pm Link  |  Quote  |  Print  |  Notify Moderator
What size?
675w Solar pictures back up
Gene K 2
Posted: 03/27/21 10:19pm Link  |  Quote  |  Print  |  Notify Moderator
That's kind of odd. Same size should have the same load rating.
I just looked up some representative tires and the only difference I could find in LT245/75R16 E was the 3042 vs 3086 which I believe is simply the difference between. TRA and ETRTO rating system. I believe they are in the process of harmonizing the two systems and right now you see a slight differential based on the different air pressure charts. It doesn't really mean anything. It's just an artifact.
* This post was edited 03/27/21 10:36pm by Gene K 2 *
otrfun
On The Road
Posted: 03/27/21 11:11pm Link  |  Quote  |  Print  |  Notify Moderator
I'm guessing you have a 1-ton SRW with 18" or 20" tires. If you want a higher load capacity (>3680 lbs.) you'll probably need to upgrade to a slightly larger 295/70/18 tire. That'll net you a 4080 lb. load rating (129 load index). If you have 20" tires, you'll need to upgrade to a 295/65/20 tire (load index 129; 4080 lbs.). 18"/20" E-rated LT tires with load capacities/ratings above 3680 are very limited.
valhalla360
No paticular place.
Posted: 03/28/21 06:06am Link  |  Quote  |  Print  |  Notify Moderator
Look for the tires with the higher load index (ply ratings are outdated).
Yes, for the same size, there are different load ratings.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
SweetLou
La Quinta, CA USA
Posted: 03/28/21 07:13am Link  |  Quote  |  Print  |  Notify Moderator
It's because all tires not made equal. Some have a bit more steel in them or the compounds they use
2013 3500 Cummins 6.7 Quadcab 4x4 3.73 68FE Trans, 2007 HitchHiker Discover America 329 RSB
We love our Westie
Posted: 03/28/21 07:47am Link  |  Quote  |  Print  |  Notify Moderator
True, but generally tires of the same size and general classification are rated the same.
Bigger the tire, the higher the capacity. Taller sidewalls increase load capacity over shorter sidewalls as well.
2017 Heartland Torque T29
Posted: 03/28/21 07:49am Link  |  Quote  |  Print  |  Notify Moderator
look up tire size/capacity. Bout every tire model and every tire website has a list with size, weight, capacity, tread depth etc for all sizes of a tire model in a list.
* This post was edited 03/28/21 08:42am by Grit dog *
ktmrfs
Portland, Oregon
Posted: 03/28/21 09:31am Link  |  Quote  |  Print  |  Notify Moderator
Not quite. today for a given tire size and Load rating (C,D,E etc.) tires also have a load index giving the exact load carrying capability. You won't find much variation amongst a given load rating and size, but if you look around you will likely see some variation in load capacity. And the variation will correspond to the tire load index.
And it is more common to see a variation in car tires vs. LT tires.
2011 Keystone Outback 295RE
