RV.Net Open Roads Forum: Beginning RVing: While using my black tank flush
 > While using my black tank flush
jimbo4UT
Stafford Virginia
Posted: 03/28/21 08:47am Link  |  Quote  |  Print  |  Notify Moderator
For the first time it filled up the fresh water tank!!! There is no other valve to turn on-off so what gives?
I’m traveling today ( yes I drained the fresh water tank). Look forward to your replies.
Thanks in advance
Jimbo
opnspaces
San Diego Ca
Posted: 03/28/21 09:02am Link  |  Quote  |  Print  |  Notify Moderator
What kind of RV are you asking about? Is the black tank flush anywhere near the fresh water hookup?
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
Monterey, California
Posted: 03/28/21 09:07am Link  |  Quote  |  Print  |  Notify Moderator
Be careful and very repetitive sanitizing the fresh water tank if you decide not to replace it.
CA Traveler
The Western States
Posted: 03/28/21 09:10am Link  |  Quote  |  Print  |  Notify Moderator
Mine have all been completely separate hose connections. I'm having a hard time understanding why a black tank flush system would have any connection to the fresh water system due to the potential for crosss contamination.
I would immediately remove and eliminate your cross connection if you have one vs a cockpit error. Then sanitize all fresh water hoses and tanks with heavy bleach multiple times. Then I'd still be leary of the fresh water safety.
2014 Grand Cherokee Overland
Bob
BB_TX
McKinney, Texas
Posted: 03/28/21 09:11am Link  |  Quote  |  Print  |  Notify Moderator
Connections mislabeled? Post a picture of your convenience center, or where ever it is that you make the flush connections.
There is no connection between the flush system and the fresh water tank unless someone really screwed up the piping.
chris3403
Jeffersonville, In
Posted: 03/28/21 02:23pm Link  |  Quote  |  Print  |  Notify Moderator
My Black Flush Tank connection is right above my Fresh Water connection.
kellem
Shenandoah valley,VA
Posted: 03/28/21 02:25pm Link  |  Quote  |  Print  |  Notify Moderator
From the way I understand your post is that by connection to the black tank flush
it immediately started filling fresh water tank which tells me it's labeled wrong.
Cross contamination from black tank to fresh water tank would be a disastrous plumbing error and highly unlikely given it's simplicity.
Ed_Gee
Central Oregon coast
Posted: 03/28/21 04:21pm Link  |  Quote  |  Print  |  Notify Moderator
I suspect Chris3403 likely nailed the problem. Easy enough to mistakenly plug the flush hose into the city water inlet if they are close to each other and operator not paying enough attention. Still, since the OP has not responded with more specifics we are all left to just guess how that could have occurred.
Ed - on the Central Oregon coast
2018 Winnebago Fuse 23A
Scion xA toad
jimbo4UT
Stafford Virginia
Posted: 03/28/21 05:02pm Link  |  Quote  |  Print  |  Notify Moderator
Guys here is what I know. Opened the black tank turned on the water and a slow stream came out of the sewer hose (water was clear) the other side of the rv were you gravity feed the fresh water tank it was pouring water out of it. That’s all I know
Jimbo
Ed_Gee
Posted: 03/28/21 05:21pm Link  |  Quote  |  Print  |  Notify Moderator
Appreciate the feedback ... but considering how many different varieties of RV plumbing options there are ... still unclear just exactly where did you put the hose to flush out the black tank .... was it screwed to a dedicated and labeled receptacle for black tank flush ... or something else? Also, make / model / year of your RV might be extremely helpful for some of us to try to figure out just what was going on ....
