RV.Net Open Roads Forum: Beginning RVing: While using my black tank flush
 > While using my black tank flush
Ed_Gee
Central Oregon coast
Posted: 03/28/21 05:24pm Link  |  Quote  |  Print  |  Notify Moderator
Ed_Gee wrote:
Appreciate the feedback ... but considering how many different varieties of RV plumbing options there are ... still unclear just exactly where did you put the hose to flush out the black tank .... was it screwed to a dedicated and labeled receptacle for black tank flush ... or something else? We need some specifics , like make / model / year of your RV might be extremely helpful for some of us to try to figure out just what was going on ....
Ed - on the Central Oregon coast
2018 Winnebago Fuse 23A
Scion xA toad
jimbo4UT
Stafford Virginia
Posted: 03/28/21 05:36pm Link  |  Quote  |  Print  |  Notify Moderator
2021 sunseeker 3010ds
jimbo4UT
Stafford Virginia
Posted: 03/28/21 05:37pm Link  |  Quote  |  Print  |  Notify Moderator
The connection is right above the tank pulls where I connected the hose
MitchF150
Puyallup, WA
Posted: 03/28/21 05:59pm Link  |  Quote  |  Print  |  Notify Moderator
I've got a 2019 Rockwood and the only way to fill the fresh water tank is to fill it from the side of the trailer, up front where the tank is.
At the rear of my rig, it has the black tank flush connection and the city water connection and also a winterization connection.
I know some of the higher end units have those city water connections that will also fill the fresh water tank if you flip a valve, but that's usually in a compartment and clearly marked? Dunno, because I don't have that feature... [emoticon]
The only valve I have is for that winterization connection and you have to flip to to suck in your RV AF...
One reason I don't do that, ha, ha... But that's a whole other topic!
My Dad made the mistake of hooking up to the black tank connection thinking it was the city water connection and not too long later, had flooded his 5th wheel and with the toilet in the 5th wheel part of the rig, it was a mess...
He got it all cleaned out and all, but cost a lot of $$ and time..
Good luck! Mitch
schlep1967
Harrisburg, PA
Posted: 03/29/21 05:30am Link  |  Quote  |  Print  |  Notify Moderator
jimbo4UT wrote:
Guys here is what I know. Opened the black tank turned on the water and a slow stream came out of the sewer hose (water was clear) the other side of the rv were you gravity feed the fresh water tank it was pouring water out of it. That’s all I know
Jimbo
With the info given above I would guess somebodyinstalled a flush kit and put it into the wrong tank. If this is a new unit contact the manufacturer.
If it is used you can try the manufacturer but odds are they will tell you the previous owner self installed a flush kit into the wrong tank. If that is the case properly lable it as a fresh water fill port, sanitize your freshwater system as you should every year and move on.
2008 Dodge Ram 2500 Diesel
2009 Open Range 385RLS
Pull-Rite Super Glide
PastorCharlie
NC
Posted: 03/29/21 07:44am Link  |  Quote  |  Print  |  Notify Moderator
Reads like an early April Fool Joke.
Posted: 03/29/21 03:18pm Link  |  Quote  |  Print  |  Notify Moderator
If you went to flush the black and it filled the fresh... You used the wrong connection or the connections are mis-labeled (This. by the way, is very common.. labels screwed up)
jimbo4UT
Stafford Virginia
Posted: 03/29/21 03:23pm Link  |  Quote  |  Print  |  Notify Moderator
I’ll check Thursday when I get back to the rv. On a very good side note I sold my house in 4 days. It’s back to full time on April 28th
Jimbo
Stafford Virginia
wopachop
Who run bartertown
Posted: 03/30/21 11:29am Link  |  Quote  |  Print  |  Notify Moderator
Jimbo
Fun to troubleshoot. Are you saying that you opened the black tank valve first, no water came out, then you turned on water pressure and saw water begin to exit the black tank?
That would go against my first thought. My best guess is that there was already a small bit of water in the black tank. You opened the valve and saw water come out. But if water is exiting the fresh water overflow, while you have water pressure turned on, then it must mean you were hooked up to the fresh water fill. Crazy part is you claim the fresh water fill is on the other side of the trailer.
Maybe the plumbing line of the black tank flush has a small leak. You might have been flushing the black tank at the same time youre leaking water onto the ground.
Are you positive the fresh tank was full? I think you said that you drained the fresh tank. Did you literally dump 100 gallons on the ground? Not making fun, just trying to figure out what we can call facts.
The dealer must have prefilled the fresh tank for you?
