RV.Net Open Roads Forum: Travel Trailers: Slide out issue
 > Slide out issue
troy t
home
Posted: 03/28/21 03:09pm Link  |  Quote  |  Print  |  Notify Moderator
Did a little You-tubing and I do have the Schwintek system. Grabbed a ladder and went up to lok at the top where the motor is and realized I need to replace the seal across the top. Doesn't look like a horrible job, has anybody done that?
MFL
Midwest
Posted: 03/28/21 03:46pm Link  |  Quote  |  Print  |  Notify Moderator
There are several different styles of slide seals. I replaced my top one, which was a D-bulb style, that just slides in a track on the wiper. It was a simple job.
Jerry
ORbiker
Springfield, Oregon
Posted: 03/28/21 07:00pm Link  |  Quote  |  Print  |  Notify Moderator
Read about calibrating the Schwintek slides. Doing this will help your slides go in and out squarely.
Once you replace the one damaged seal lube the others with a silicone spray. I do the seal and the side of the slides to make them slick (so that the seal will slide easily). KEN
Backpacker and tent camper all my life. Motorcycle trips with a tent too 1978 to Present. 2016 Grand Design 380TH as of 10-29-2015. Now a New 2018 374TH-R Solitude as of 3-16-19. 10-19-18-traded truck for a 2016 Ram 3500 DRW Laramie Crew Cab 4x4 Long Box.
WayneAt63044
St. Louis, MO
Posted: 03/28/21 07:19pm Link  |  Quote  |  Print  |  Notify Moderator
I, too, have the Schwintek slide and have replaced the top seal as described above. I find any wet lubricant like silicon makes the seals sticky and creates drag. Baby powder is a better option and there is very little friction and it doesn't soften or deteriorate the seals.
2012 Forest River V-Cross Vibe 826VFK
pulled by 2009 Ram 1500 Quad Cab Hemi
troy t
home
Posted: 03/28/21 08:34pm Link  |  Quote  |  Print  |  Notify Moderator
Just the bulb seal looks easy but on the top and one side I need to replace the wiper seal also. Fun stuff. Makes my memories of the old hybrid much fonder!
 > Slide out issue
