RV.Net Open Roads Forum: Tech Issues: AirConditioner Discharge Openings
 > AirConditioner Discharge Openings
Bob Landry
Austin, texas
Posted: 03/28/21 11:32am Link  |  Quote  |  Print  |  Notify Moderator
Are the discharge opening, where the uunit mate with the duct the same size for 13.5 and 15K units. Wondering if new RVs are ducted with larger duct so that either size capacity can be instaled. Have a 15K AC and looking to add a second.
2011 Keystone Outback 277RL
jdc1
Rescue, Ca
Posted: 03/28/21 12:09pm Link  |  Quote  |  Print  |  Notify Moderator
Same measurements.
Posted: 03/28/21 04:32pm Link  |  Quote  |  Print  |  Notify Moderator
The A/C consists of 3 or 4 (or 5 in a few cases) parts
The upper unit. this is the "Guts" of the operation this is what is 13.4 15 or other thousand BTUs.
The part that goes through the roof, This is the duct adapter and the same is used for both sizes. This part may include electronics and or controls
The grill (indoor cover
Optional 4th part: Thermostat on wall
Optional 5th part: Adapt-a-kit because Carrier was the OEM.
dougrainer
Carrolton, Texas
Posted: 03/29/21 09:01am Link  |  Quote  |  Print  |  Notify Moderator
All roof top RV AC holes are 14.5 inches square. Been that way for more than 50 years. Doug
Itakethe5th2011
Moreno Valley, Ca
Posted: 03/29/21 10:22am Link  |  Quote  |  Print  |  Notify Moderator
Before you add a second AC, check out RV Airflow System. It will boost the ac duct output by 40-50%. I just installed one, but it hasn't been hot enough to really see how much faster rv cools down. I did turn fan on and the air coming out of ducts is much much better.
