RV.Net Open Roads Forum: Truck Campers: Buying a new TC
 > Buying a new TC
JimK-NY
NY
Posted: 04/01/21 05:51am Link  |  Quote  |  Print  |  Notify Moderator
noteven wrote:
The manufacturer weight placard for my Cirrus camper is very accurate.
The "placard" gives the dry weight of the specific completed unit. The OP is looking at advertised weights which are often much different because they do not include upgrades, options, modifications.
For my camper the advertised spec weight did not include the weight of the AC, microwave, or awnings. The specs also did not include the weight for an extended overhang to accommodate a queen sized bed.
JimK-NY
NY
Posted: 04/01/21 06:01am Link  |  Quote  |  Print  |  Notify Moderator
billtex wrote:
GVWR is pretty much meaningless for carrying a TC. Rear axle rating (tires/wheels) is what you need to pay attention to. I carry a much heavier camper on SRW F350 gasser. I am within my axle rating by several hundreds pounds on stock Michelin tires.
...... Bill
The GVWR is certainly not "meaningless". Typically that load rating is based on the load capacity of the tires. The stock tires for the OPs truck are 275/65r/18 with a load capacity of 3415 or a combined axle load of 6830. Replacing tires with a larger size might be the first step for upgrading but manufacturers often use rims that are similarly rated so it might be necessary to upgrade rims and wheels. That leaves the shocks and springs which were not designed for the heavier weight. That leads to another round of upgrades. Fact is the camper is too heavy for the truck the OP bought.
Bert the Welder
Van. Island
Posted: 04/01/21 10:02am Link  |  Quote  |  Print  |  Notify Moderator
Then on top of that, add the rarely mentioned components/brackets/fasteners that mount/hold all those components to the truck frame. Spec's of those would also go into the GVWR.
If you are just converting your truck camper to a shack and setting it down on a rear axle only, then the axle rating is going to be your primary consideration. Next would be keeping balanced while you get in and out......
"> 1998 GMC 2500, 10.5 Okanagan, My better/smarter half, George and Finnegan(APBT), all I need.
noteven
Turtle Island
Posted: 04/01/21 01:02pm Link  |  Quote  |  Print  |  Notify Moderator
Actually it lists and includes the base camper, plus fresh water, plus propane, plus 2.2 lbs of ice in the fridge, plus options: rear awning, roof racks, backup camera, solar kit, glow step, pass through window.
It is accurate.
noteven
Turtle Island
Posted: 04/01/21 01:03pm Link  |  Quote  |  Print  |  Notify Moderator
But yes when you look at advertised base weight you add weight for factory options.
A little work with your dealer should make it possible to discover this info.
JimK-NY
NY
Posted: 04/01/21 05:38pm Link  |  Quote  |  Print  |  Notify Moderator
Unfortunately that depends on the manufacturer and whether they provide that data to the dealer or prospective buyer. Look at manufacturer specs and you will often see no mention of the weight of accessories.
In addition I have not seen dealers who are interested in warning or discussing the weight issue with prospective buyers.
noteven
Turtle Island
Posted: 04/01/21 08:14pm Link  |  Quote  |  Print  |  Notify Moderator
I had to sign a waiver at time of delivery that the weight and center of gravity of the camper as equipped and what payload capacity truck was recommended was explained and discussed.
billtex
RI
Posted: 04/02/21 05:47am Link  |  Quote  |  Print  |  Notify Moderator
JimK-NY wrote:
...... Bill
You are confusing RAWR with GVWR.
2020 F350 CC LB
Eagle Cap 850
25'Airstream Excella
"Good People Drink Good Beer"-Hunter S Thompson
run100
Arizona
Posted: 04/03/21 09:49am Link  |  Quote  |  Print  |  Notify Moderator
This past February marked our 20-year anniversary of truck camping. The span of years has included two truck campers and two F350's. We added air bags to the first truck, but have been running our 2012 6.7 s/b stock. Both set-ups handled amazingly well - especially our current truck. Uphill, downhill, curvy roads and even high winds have never presented an issue. Honestly, it is extremely fun to drive and we did so again this week, with a couple days of mid-week camping.
Although each truck and camper combination will have different specs and characteristics, I also agree with others that suggest running stock, at first, to see if you're satisfied with how the rig handles.
Good luck with your upcoming purchase. Most of all - Be safe and have FUN!
2012 F350,6.7L Diesel,4x4,CC,SB,SRW
2013 Lance 855S
 > Buying a new TC
