RV.Net Open Roads Forum: Truck Campers: Buying a new TC
 > Buying a new TC
Mammoth501
East Kootenay BC
Posted: 03/28/21 08:05pm Link  |  Quote  |  Print  |  Notify Moderator
Hey, I'm new to this site and Joining the RV world [emoticon] So I've got a 2020 Ram 3500 6.7 cummins SRW 6"4" box and ordered the 2021 Northern Lite 8-11 EXLE. There're 2 things that I'm kinda hung up on and can't decide. (1) Should I really get the A/C? I live in lower BC and the summers don't get to hot here. We might get 2-3 weeks of +30C (86f) but other than that it's bearable. So I was thinking of saving the weight and eventually more sealant and getting the A/C deleted. I'm just not familiar with a TC and don't know if it gets hotter than usual in a small rig like that.
(2) Do I need some kind of suspension upgrade? I should mention that the TC I'm getting has a dry weight of around 2800lb. So I was thinking of getting the torklift lower stableload as a start and then go from there. Or is that a waste of time and money?
Any advice will be greatly appreciated!
Longshore
California
Posted: 03/29/21 06:01am Link  |  Quote  |  Print  |  Notify Moderator
Mammoth that sounds like sound thinking. I too am new. I was looking at the 8-11 also but went with the Wolf Creek 890, which is 500? lbs lighter so I don't plan on doing any up grades. I already have the helper springs. You will know straight off if you do need/want to upgrade.
That is a top of the line camper have fun with it!
jimh406
Western MT
Posted: 03/29/21 06:11am Link  |  Quote  |  Print  |  Notify Moderator
You will be spending a lot of money. I expect that there will still be hole for a vent if you delele the AC. You probably don’t know if you’ll end up hanging out at Okanogan, etc or not when the weather turns unnormally hot. I’d get the AC, but do get the low profile model which is quite a lot shorter in height.
We don’t use our AC a lot, but I do remember stoppping near Yellowstone and on one of those hot nights it was 95 F at dark. Obviously, just a fan would have never cooled off for sleep.
Fyi, I got my first TC, but not first RV almost 15 years ago. A lot has changed including the truck, but I still have the same TC. So, I’d say buy an AC to future proof the rig.
MFL
Midwest
Posted: 03/29/21 07:32am Link  |  Quote  |  Print  |  Notify Moderator
Never owned a truck camper, but suspect the AC to be the same as other RVs. Most ACs have a dependable roof gasket, that requires no additional sealant. The weight savings is not much either, so I would recommend getting the AC. Just needing it once in a while, you will be glad you have it.
Jerry
billtex
RI
Posted: 03/29/21 10:29am Link  |  Quote  |  Print  |  Notify Moderator
We live in New England and ordered our current Eagle Cap sans AC. Don’t need it here and the weight up high won’t help handling.
We do have a fantastic fan that is great. If it does get hot turn fan on exhaust and crack the small slider window, or bedroom windows at night, you’d be surprised how well that works.
We boondock a lot also, so AC won’t really help us. The ceiling fan runs on 12V.
As far us suspension, NL (nice camper BTW) aren’t all that heavy. You’ll probably be fine with the one ton. You can always add Stableloads later if you think you need them.
Congrats!
2020 F350 CC LB
Eagle Cap 850
25'Airstream Excella
"Good People Drink Good Beer"-Hunter S Thompson
noteven
Turtle Island
Posted: 03/29/21 10:42am Link  |  Quote  |  Print  |  Notify Moderator
I’ve had 5 truck campers over the years. 8ft no cab over, Kodiak, Snowbird with slide, Alaskan, Cirrus.
Try without A/C because in BC there are lots of trees in the way of the scenery but the positive is you can get in the shade.
Order A/c pre wire from the factory in case you want to install a roof one in the future.
You will want an efficient 2way fan mounted somewhere.
Use the camper with the truck before you spend $1 on “upgrades”. Today’s trucks are pretty capable. Use the $$ and time for travellin’ and truck campin in places and elevations where it cools off at night...
PS - if you like to camp in the trees I would be tempted to get a quote on a pair of “branch rails” like expedition trucks have along the edge of the roof to help keep tree branches off the body work of the camper.
specta
utah
Posted: 03/29/21 11:11am Link  |  Quote  |  Print  |  Notify Moderator
Better to have it and not need it than to need it and not have it.
Kenny
2011 Chevy 2500 HD 6.0L 4wd
JimK-NY
NY
Posted: 03/29/21 11:23am Link  |  Quote  |  Print  |  Notify Moderator
I would get the AC even though I don't use mine very often. A TC can get pretty hot baking in the sun on even a moderately warm day. The fanastic fan and portable fan I have do little to help cool the TC. A few minutes with the AC can make a big difference in comfort. It might also help with resale if that is a concern. As to weight savings, the AC unit is going to weigh about 90#. The loaded TC is likely to weigh over 4000# so your weight savings would be about 2% of the TC weight and way less than 1% of the weight of the truck and TC.
Anza-Borrego Desert SP area
Posted: 03/29/21 11:48am Link  |  Quote  |  Print  |  Notify Moderator
I vote for getting the A/C prewire. You can easily add the A/C later if desired.
And I vote for getting the TC first and then determining what you need to add to the truck to carry it.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, WindyNation 300 watt solar-Lossigy 200 AMP Lithium battery. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
Posted: 03/29/21 11:55am Link  |  Quote  |  Print  |  Notify Moderator
For sure, the AC is not as necessary in the BC mountains as many places. We've done without for years. Only used it rarely prior or wished we had it a few times. Although I believe if I was spending big bucks for a brand new high end TC, I'd get AC. Like other "options", oven, microwave, etc, it's handy whether its your personal preference or not and think resale.
Don't worry about leaks if that's part of the consideration, IMO.
On the truck, I'd bring the camper home on stock suspension, get it loaded, set up, etc and then decide what upgrades to the suspension may be necessary.
Also, lower stable loads are the easiest upgrade to "mock up" quickly and for free to see if that's what works for you.
My guess, based on having some 4th Gen Ram 3500 srws in the past and also big TCs (not in combination though) is you'll want a sway bar and some minor load carrying mod, whether it's stable loads or something else.
Have fun!
2017 Heartland Torque T29
 > Buying a new TC
