RV.Net Open Roads Forum: First time RVing. What should we consider? Insurance?
 > First time RVing. What should we consider? Insurance?
docsouce
Seekonk Ma.
Posted: 04/04/21 03:09pm Link  |  Quote  |  Print  |  Notify Moderator
Great suggestions given. When you pick up your RV, stand away from the side and look at the distance from the back wheels to the end of the RV. When you take a corner or leave a tight area that tail swings way out and even though the rear wheels and most of the back of the RV has cleared the obstruction that last 3 or so feet is still swinging out.. example: you pull up to the gas pump. It's a bit tight so you are close to the pump which is on the drivers side. When you finish and are ready to leave you decide you want to turn to the right. If you turn to soon the tail will hit the pump or one of the guards as it swings out. Be sure you have enough room for that back end to clear before turning..saves a lot of trouble..
* This post was edited 04/04/21 03:30pm by docsouce *
2020 JAYCO 26XD
Just right for the two of us!
