RV.Net Open Roads Forum: Travel Trailers: Help identify bearings parts
 > Help identify bearings parts
alexey75
Nova Scotia
Posted: 03/30/21 09:24pm Link  |  Quote  |  Print  |  Notify Moderator
I'm looking to repack the bearings of our TT. I would like to buy in advance some parts like seals, bearings, washer erc.
How can I identify what are the existing parts before I dissemble it?
The only thing that I was able to see, is that I have Dexter 4400 lbs axle.
azdryheat
Tucson, AZ
Posted: 03/30/21 11:14pm Link  |  Quote  |  Print  |  Notify Moderator
Bearings, races, and seals have identifying numbers stamped on them.
2013 Chevy 3500HD CC dually
2014 Voltage 3600 toy hauler
2016 RZR 900
Lynnmor
Red Lion
Posted: 03/31/21 12:46am Link  |  Quote  |  Print  |  Notify Moderator
Here is one source.
bucky
Raleigh metro
Posted: 03/31/21 03:49am Link  |  Quote  |  Print  |  Notify Moderator
Here is info from the mother ship
click here
2005 Cummins 3500 2WD LB quad cab dually pulling a 2014 Blue Ridge 3025RL
JIMNLIN
Oklahoma
Posted: 03/31/21 06:19am Link  |  Quote  |  Print  |  Notify Moderator
Hmmm... I've R&R lots of trailer bearings when I hauled for a living and found the hard way axle makers bearing/seals recommendations aren't always whats on the spindle/hub.
Best bet is pull a hub and check the seal number...then remove all the race/bearing sets and get the numbers from them.
If your (or others) are handy with dial calipers and outside mics use those to find bearings/seal inside and outside measurements. Then let the bearing store match up the numbers.
We've had members say they carried a set of bearings/seals for several years and found out later they didn't fit.
midnightsadie
ohio
Posted: 03/31/21 06:42am Link  |  Quote  |  Print  |  Notify Moderator
I just pull them out clean up. the numbers are on the bearing and seals I use only timken roller bearings. and double lip seals.
Posted: 03/31/21 10:37am Link  |  Quote  |  Print  |  Notify Moderator
“How can I identify what are the existing parts before I dissemble it?”
Just sayin.
2017 Heartland Torque T29
Posted: 03/31/21 10:41am Link  |  Quote  |  Print  |  Notify Moderator
OP, use the links provided. Or were you looking for some specific recommendations, since google seems to find what you need very easily)?
Worst case, but small chance, something is different from what you ordered.
However I’m sure it’s a common bearing size and you can likely get bearings and seals in stock at most any auto parts store if you have disassembled it.
alexey75
Nova Scotia
Posted: 03/31/21 02:35pm Link  |  Quote  |  Print  |  Notify Moderator
Thank you guys. I will buy some parts in advance and will go to replace just in case it wont fit.
Are you replacing seals and washers every year or just when needed?
azdryheat
Tucson, AZ
Posted: 03/31/21 06:41pm Link  |  Quote  |  Print  |  Notify Moderator
Just sayin.
You can't. It's always best to tear down one hub and get the numbers.
