RV.Net Open Roads Forum: How to build a LiFePo4 battery bank.
 > How to build a LiFePo4 battery bank.
Page of 9
time2roll
Posted: 10/25/21 07:54pm Link  |  Quote  |  Print  |  Notify Moderator
No. The heaters did not come on. Set to on 40, off 45. I did test the system with an ice cube before attaching the sensor to the battery. Collectively just under 6 amps was moving evenly through the heaters giving about 60 watts of heat. No power source at that point so no temperature rise verification or performance was measured.
I assume it is good to 20f, maybe lower, and covers about the worst I would see. Could be they never activate. Glad to know they are there to buy some time so as not to create an immediate panic to roll out.
Not really an expedition vehicle. Not likely to be in Canada in winter.
675w Solar pictures back up
Itinerant1
Itinerant
Posted: 10/26/21 02:25am Link  |  Quote  |  Print  |  Notify Moderator
Time2roll glad everything is working out. Give it a little more time and you'll really stop paying attention to the batteries because they just there in the background working effortlessly with solar at all the tasks within reason. Me personally lfp is the only way now. Until you actually get them and use them, some of the lfp stories sound to good to be true. I know with mine now after 5.5 years and the paces they've been put through it's just amazing at times....no more dead lead. [emoticon]
12v 500ah (5,120Wh usable), 20 cells_ 4s5p (GBS LFMP battery system). 8 CTI 160 watt panels (1,280 watts)2s4p,Panels mounted flat. Magnum PT100 SCC, Magnum 3012 hybrid inverter, ME-ARC 50. Installed 4/2016 been on 24/7/365, daily 35-45% DOD 1,800+ cycles.
StirCrazy
Kamloops, BC, Canada
Posted: 10/26/21 07:47am Link  |  Quote  |  Print  |  Notify Moderator
dont lump all of canada into thoes cold winters haha. my normal day time high in the winter is 32 degrees but I onlu have to drive a short distance to drop that significantly. on the island if you around victoria the normal day time high is 42 in the winter, but if we go to winnipeg then it could be -40
Steve
2014 F350 6.7 Platinum
2016 Cougar 330RBK
Page of 9
