RV.Net Open Roads Forum: How to build a LiFePo4 battery bank.
 > How to build a LiFePo4 battery bank.
Page of 9
BFL13
Victoria, BC
Posted: 10/06/21 09:46am Link  |  Quote  |  Print  |  Notify Moderator
pianotuna wrote:
BFL,
Where did 5C come from?
Trojan Trillium charging specs. Also some(all?) drop-in self- heating LFPs have the battery charger (there is your generator requirement) power the internal battery heater and get the bank up to 5C before it switches the charger power over to battery charging. It takes about two hours to warm them up from -20C to 5C I saw somewhere, but not so long when it is just under freezing of course..
The better idea is obviously to not let the batts get that cold in the first place, and the DIY set-up like time2roll has built should be way better than the drop-in method.
If the bank is inside the RV you keep it warm with propane furnace or if in outside compartment, you can perhaps DIY a way to get hot air or hot water (also from propane) to it, or else you are stuck with having some kind of DC heater.
Some say you can charge the LFPs at full blast once they are above 0C freezing, but others say you should/must use a reduced charging rate between 0 and 5C, scaling up the rate, like the Trillium specs.
Not many RVs will have a converter or charger that can do higher rate charging on a bigger AH LFP bank anyway.
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
time2roll
Posted: 10/06/21 10:34am Link  |  Quote  |  Print  |  Notify Moderator
I do wonder if these self heated batteries only allow external power for heating.
675w Solar pictures back up
BFL13
Victoria, BC
Posted: 10/06/21 06:03pm Link  |  Quote  |  Print  |  Notify Moderator
Should still be able to keep them warm with heat pads, etc. Only then use the charger heating method as an emergency back-up.
I see I forgot the actual Trillium charging specs. They do allow a little charging a little below freezing, but also only allow full charging at 73F. No clue how that may apply to other LFPs.
https://www.trojanbattery.com/pdf/Trillium_UsersGuide.pdf
* This post was edited 10/06/21 07:16pm by BFL13 *
pianotuna
Regina, SK, Canada
Posted: 10/06/21 06:22pm Link  |  Quote  |  Print  |  Notify Moderator
The ones I've found online draw from the battery, and have no provision for an external energy source.
Regards, Don
pianotuna
Regina, SK, Canada
Posted: 10/06/21 06:27pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks BFL13 for the information.
BFL13
Victoria, BC
Posted: 10/06/21 06:53pm Link  |  Quote  |  Print  |  Notify Moderator
PT, this a typical blurb for a "cold weather" drop-in LFP:
"In cold temperatures, the BMS ( battery management system) disconnects from the cells to protect your battery. Prior to charging, the built-in heating systems draw power from the charger in order to heat up the battery."
Time2roll would set his BMS to allow charging at X temp, and also set his heat pad Tstat relay temp to keep them above that BMS set charging temp.
No idea where his charging rate setting might be for cooler temps, if he even does that. Once set up and camping proven after any adjustments, it should be easy after that to just go camping no worries.
* This post was edited 10/06/21 07:05pm by BFL13 *
StirCrazy
Kamloops, BC, Canada
Posted: 10/06/21 06:54pm Link  |  Quote  |  Print  |  Notify Moderator
time2roll wrote:
Itinerant1 wrote:
If the heating pads are wired directly to the batteries terminal and if needing them because the actual cells are below 32f and not the ambient temp how would a generator help unless you have a heater cube plugged into it throwing heat to the compartment.
Are you going to add extra insulation on the walls/ floor to help keep heat in and cold out during the colder months if using them during that period?
Heaters will be wired on the load side of the BMS. If the load side is powered by generator, solar or vehicle, the power will go to the battery heater.
Insulation will not be added unless it seems to be needed. Most camping is in fair weather. Not intended to be a north pole expedition vehicle. Just some minimal protection for a mild cold snap.
I think everyone is going on about a mute issue, unless the batteries are totaly dead then just the charging is going to be cut off at 32 degree ish, the discharge will still be available so the heating pads will work untill it gets down to a heck of a lot colder. if you insulate good around the batteries you may never come to this as the discharge from using/charging the batteries will create there own internal heat and with the right insulation it might be enough to keep them above zero down to a pretty cold temp, but that just theory...
Steve
2014 F350 6.7 Platinum
2016 Cougar 330RBK
Ivylog
Blairsville, GA and WPB, FL.
Posted: 10/06/21 07:05pm Link  |  Quote  |  Print  |  Notify Moderator
I just paid $350 for 8-280AH cells and $370 for 8-310AH cells. Will build 2 12V batteries out of each group of 8 cells. Bought 4 200A BMS for $240 plus probably $100 in cables and parts… works out to 90 cents/AH plus probably 20 hours of my time. Doubt the cells will be grade A so I may only have 1100 AH pushing my price to $1/AH…OH well, I can live with that as 9 months ago I thought I’d done well building 600AH for $1200.
Not worried about charge them below freezing as rarely am I in freezing weather. If needing to charge…turn off the chargers (solar included) and run the generator, putting an electric heater in the outside battery area until the cells are above freezing and then charge.
Sold 04 Dynasty to our son after 14 great years.
Upgraded with a 08 HR Navigator 45’...
time2roll
Posted: 10/06/21 07:14pm Link  |  Quote  |  Print  |  Notify Moderator
Almost too good of a price. Please update when you get them.
StirCrazy
Posted: 10/07/21 05:02pm Link  |  Quote  |  Print  |  Notify Moderator
Steve
I was thinking about this at work, and I may be wrong... it all depends on the BMS and how it is configured for the internal pass through of power. if it is just one line then the cold weather will kill the whole battery, but if they spent some money and used diods and did two internal paths then you could controle charging and discharge independently. I guess we would have to dig into the BMS construction to know for sure...
Steve
Page of 9
