RV.Net Open Roads Forum: Class C Motorhomes: Nexus Chassis noise
 > Nexus Chassis noise
Ellen Higgins
Marmora
Posted: 03/31/21 09:46am Link  |  Quote  |  Print  |  Notify Moderator
I have a 2020 Nexus Viper 27V on 2019 Ford E450 chassis. There is a vibration noise coming from underneath the chassis, it is not in the engine. The vibration noise is only heard between 60 and 65 MPH. Below 60 and above 65 no vibration noise. Any suggestions as to what might be the cause?
Tyler0215
Iowa
Posted: 03/31/21 12:30pm Link  |  Quote  |  Print  |  Notify Moderator
Get up to speed when vibration starts, shift into neutral and see if the vibration goes away. If it does have the U joints and carrier bearings checked.
DrewE
Vermont
Posted: 03/31/21 12:55pm Link  |  Quote  |  Print  |  Notify Moderator
A few possibilities exist; offhand, and approximately in order of my guessed likelihood, it might be:
1. Universal joint/carrier bearing/drive shaft balance issues.
2. Out of balance or out of round tires/wheels.
3. A whiney sound, particularly one that varies with load, could be noise from the differential.
bobndot
Posted: 03/31/21 01:10pm Link  |  Quote  |  Print  |  Notify Moderator
Is it a vibration or a noise or both ?
ron.dittmer
North-East Illinois
Posted: 03/31/21 09:42pm Link  |  Quote  |  Print  |  Notify Moderator
DrewE mentions this and I support his comment. I have read a rare few complaints over the years where modifying (stretching) the wheel base effecting the length of the drive shaft was the culprit. The change in length of the drive-shaft requires it to be rebalanced. The "Ford approved" company that modified the wheel base either over-looked or improperly balanced the drive shaft. Some drive shafts get quite long and segmented, making them very sensitive to being out of balance. If not balanced right, vibration and/or other strange noises are generated. One thing certain, you do NOT want to ignore it.
* This post was edited 04/12/21 01:30am by ron.dittmer *
2007 Phoenix Cruiser model 2350, with 2006 Jeep Liberty in-tow
klutchdust
Orange, California
Posted: 03/31/21 10:51pm Link  |  Quote  |  Print  |  Notify Moderator
Don't forget the tail shaft of the transmission. Most likely drive shaft. Rarely do carrier bearings and universal joints fail on that new of a vehicle, but it is possible.
docsouce
Seekonk Ma.
Posted: 04/01/21 06:28am Link  |  Quote  |  Print  |  Notify Moderator
If you have a chance look up "65 MPH Drone and loud banging in cabover curved panel" on google. This post from the Jayco Owners Forum might be of some help to you. It offers some very useful information on the possible cause of this. It did help me to eliminate this annoying issue on my 2020 Jayco 26XD class C. The second half concerning the banging of course doesn't apply here. Read it through, it bounces around a bit.
* This post was edited 04/01/21 07:21am by docsouce *
2020 JAYCO 26XD
Just right for the two of us!
bobndot
Posted: 04/01/21 09:39am Link  |  Quote  |  Print  |  Notify Moderator
Take it to a tire shop. I would think that inspecting tires would be the easiest and cheapest thing to do. Maybe swap the front tires with the rear tires and drive it to see if that helps.
I once had a tire that could not be balanced, it was a bad tire and had to be replaced. Try to eliminate a tire problem first.
Ellen Higgins
Marmora
Posted: 04/04/21 08:51am Link  |  Quote  |  Print  |  Notify Moderator
To bobndot, it is mostly a noise, with a little vibration
Ellen Higgins
Marmora
Posted: 04/04/21 08:53am Link  |  Quote  |  Print  |  Notify Moderator
Thank you to all the great comments and suggestions. Finding a Ford dealer that has a lift in their shop large enough for an RV is difficult. I finally found one, almost 100 miles from where I live and have made an appointment.
