a-d-s
North Vancouver, BC
Mostly been posting over on the f150gen14 forums lately, but thought I'd share my good news. My 2021 F-150 HDPP has now been built and in transit, set for an Apr/26 delivery. The fancy new Ford VIN/Payload site confirms my yellow sticker will be 2536 lbs, about 30lbs over what I thought based on the order guide. We'll see if that holds true.
Might be a bit tight to do the break in and get it all setup for my first trip in May. It will be painful to use the old truck, but that's life.
2021 F-150 HDPP EcoBoost
2016 Coleman 262BH
Reese Dual Cam - 1200lb
ktosv
Grand Rapids, MI
Congrats! You are lucky as Ford just announced a two week shutdown and reduced over time for the F150 plant(s).
Kevin and my...
Wife and six kids
2017 Suburban (5.3L/6A/3.08)
6x12 Enclosed Utility
Sold...2011 Express 3500 (6.0L/6A/3.42)
Sold...2010 Passport Ultra Lite 2910
a-d-s
North Vancouver, BC
Yes lucky indeed, although I did purposefully order it with minimal options. Anything that can be added later (bed liner, running boards etc.) I will do after it arrives. I've heard stories that trucks are built and sitting there awaiting some trivial option or accessory.
Reisender
NA
Nice. Congrats.
pitch
NY
a-d-s wrote: Yes lucky indeed, although I did purposefully order it with minimal options. Anything that can be added later (bed liner, running boards etc.) I will do after it arrives. I've heard stories that trucks are built and sitting there awaiting some trivial option or accessory.
Well computer chips are hardly what I would describe as some trivial option, but ok we'll go with that!
Dadoffourgirls
China, MI USA
pitch wrote: a-d-s wrote: Yes lucky indeed, although I did purposefully order it with minimal options. Anything that can be added later (bed liner, running boards etc.) I will do after it arrives. I've heard stories that trucks are built and sitting there awaiting some trivial option or accessory.
Computer chips are definitely causing a major issue. However, there have been shortages of certain accessories. I know GM stopped allowing orders with certain running boards, certain floor mats, etc.
When I ordered my GMC in November, they were not going to build until March if I stayed with color matching wheel openings. That is why I have black.
Dad of Four Girls
Wife
Employee of GM, all opinions are my own!
2017 Express Ext 3500 (Code named "BIGGER ED" by daughters)
2011 Jayco Jayflight G2 32BHDS
a-d-s
North Vancouver, BC
Dadoffourgirls wrote: pitch wrote: a-d-s wrote: Yes lucky indeed, although I did purposefully order it with minimal options. Anything that can be added later (bed liner, running boards etc.) I will do after it arrives. I've heard stories that trucks are built and sitting there awaiting some trivial option or accessory.
While chips for Sat-Nav are a problem, I have also heard things like wheel well liners, work-surface and running boards are causing delays.
Gene K 2
a-d-s wrote: Mostly been posting over on the f150gen14 forums lately, but thought I'd share my good news. My 2021 F-150 HDPP has now been built and in transit, set for an Apr/26 delivery. The fancy new Ford VIN/Payload site confirms my yellow sticker will be 2536 lbs, about 30lbs over what I thought based on the order guide. We'll see if that holds true.
My '18 says 1907 on the Yellow Sticker and 1907 on the Ford Fleet Live VIN Specific Calculator so I suspect it's likely correct.
joshuajim
Mojave Desert
Wow! That’s almost exactly what my 2013 HDPP has. 2,592 #
RVing since 1995.
Sjm9911
New Jersey
Just make sure, didn't ford have a recall because of bad stickers?
2012 kz spree 220 ks
2020 Silverado 2500
Formerly a pup owner.
