RV.Net Open Roads Forum: Tow Vehicles: The Unicorn has almost landed!!
Search only in Tow Vehicles
 > The Unicorn has almost landed!!
Sjm9911
New Jersey
Posted: 04/01/21 08:28pm Link  |  Quote  |  Print  |  Notify Moderator
Opps , that was just the super duties.
2012 kz spree 220 ks
2020 Silverado 2500
Formerly a pup owner.
Gene K 2
Posted: 04/03/21 06:41pm Link  |  Quote  |  Print  |  Notify Moderator
a-d-s wrote:
Mostly been posting over on the f150gen14 forums lately, but thought I'd share my good news. My 2021 F-150 HDPP has now been built and in transit, set for an Apr/26 delivery. The fancy new Ford VIN/Payload site confirms my yellow sticker will be 2536 lbs, about 30lbs over what I thought based on the order guide. We'll see if that holds true.
Might be a bit tight to do the break in and get it all setup for my first trip in May. It will be painful to use the old truck, but that's life.
I have been unable to find a truck who's yellow sticker payload doesn't match the VIN Specific Calculator. It appears highly unlikely that yours will not match.
a-d-s
North Vancouver, BC
Posted: 04/03/21 11:49pm Link  |  Quote  |  Print  |  Notify Moderator
That's good news!
2021 F-150 HDPP EcoBoost
2016 Coleman 262BH
Reese Dual Cam - 1200lb
a-d-s
North Vancouver, BC
Posted: 05/20/21 05:15pm Link  |  Quote  |  Print  |  Notify Moderator
Well it's in! Payload is as expected. With only a few hundred miles on it, I can say it has exceeded my expectations. Maybe that is on account of reading way too many forums on all the little obscure issues some people have. Or maybe it's because I am coming from a 2008 2500...the ride in this is soooo much better. The power is ridiculous, even though I haven't really goosed it yet, still in the break in period. First tow in just over a month from now!
Reisender
NA
Posted: 05/20/21 05:22pm Link  |  Quote  |  Print  |  Notify Moderator
Fantastic colour. Beautiful. Congrats. Looks like a great truck.
Posted: 05/20/21 05:42pm Link  |  Quote  |  Print  |  Notify Moderator
^ Nice rig! Congrats!
But shame on Ford for using literally the schittiest, lowest load rated tires humanly possible, especially on a HDPP truck!
They literally shoed it with tires that will be right at max load +/-, at the stated payload spec. (Unless that sticker is wrong and it gots better tires than the sticker says)
2017 Heartland Torque T29
a-d-s
North Vancouver, BC
Posted: 05/20/21 11:01pm Link  |  Quote  |  Print  |  Notify Moderator
Haha, you prob can't see in the pic, but I had the dealer swap them with Falken Wildpeak AT3W Load Range E tires. I was really happy with them on my old truck and I didn't want to mess around with LRC tires. They look way better too!
Anyone in the Vancouver area want to buy those OEM tires, they are on craigslist - they come free with Grit Dog's seal of approval!
a-d-s
North Vancouver, BC
Posted: 05/20/21 11:04pm Link  |  Quote  |  Print  |  Notify Moderator
Went for a drive tonight and hit some scales. It comes in at 5368 lbs (3146 lbs RA, 2222 lbs FA), so that leaves 2482 lbs for payload. Seems about right as the LRE tires are about 15 lbs heavier a corner. This was with a full load of gas and a few odds and ends in the truck.
Posted: 05/21/21 09:23am Link  |  Quote  |  Print  |  Notify Moderator
I think you meant the RA is 2222lbs.
Yes, it looked like "nice" tires on the truck, so makes sense and good call IMO. I didn't pick up on it initially, because different models actually come with aggressive tires right off the line, unlike I recall in the olden days.
But (not that I endorse it for others) FWIW, I've run countless new 1/2 tons in construction work, starting out with whatever the cheapest C load tires they put on that year. I've basically tried to pop them (hard to get your boss or equip dept to spring for new tires on a new truck...lol). Can't think of a half ton, save for my newest company truck (because I'm a desk jockey mostly now) that I haven't at some point put 50-60psi in the rear tires that were generally 44psi rated or similar, and used them like that repeatedly, hauling heavy payload or trailers. They've always come out unscathed.
blt2ski
Kirkland, Wa
Posted: 05/21/21 10:57am Link  |  Quote  |  Print  |  Notify Moderator
LR c would be fine on that truck. Your going to have 2500-3000 lbs capacity per tire. Ask yourself, are you really going to put 8000 lbs per axle on your truck?
My new to me used chebby has 265-65-18s in 8.5" rims. Really needs 285s on that width. But ALL the 285-60 or 65 series ties are 10 ply. No XL or 6 ply options. Not sure I want an extra 15 lbs per corner to turn burning up HP either. Can fin 275s in XL or c ratings....may have to go that route.
At this point in time, I need to burn these GY GSA pos tires up asap. They spin on ANY wet pavement. We have plenty of that here in WA.
Nice truck too.
Marty
2014 Chevy 1500 Dual cab 4x4
