RV.Net Open Roads Forum: new Ford 7.3 gas with 3.55 axle ratio, does it work?
 > new Ford 7.3 gas with 3.55 axle ratio, does it work?
Page of 5
Americamper
Anniston AL
Posted: 03/31/21 05:54pm Link  |  Quote  |  Print  |  Notify Moderator
Anyone have the new Ford 7.3 gas with 3.55 axle ratio? If so does it work out for a 2500# TC?
2000 F250 Superduty 7.3 SB SRW, E rated Michelins, Torklifts, fastguns,2004 Northstar Laredo, , Ducati Hypermotard 1100, KTM 250XC
Posted: 03/31/21 06:55pm Link  |  Quote  |  Print  |  Notify Moderator
Huh?
Umm yeah, I mean, it’s got more than enough snort to haul around a TC.
2017 Heartland Torque T29
BradW
Mayor of Flat Rock
Posted: 03/31/21 07:22pm Link  |  Quote  |  Print  |  Notify Moderator
I don't have one, but I would say no, especially if you also plan on towing anything or driving in the mountains.
Flat ground, no towing, a TC which actually weighs 2,500 lbs and plenty of time to get where you are going, probably OK.
I once drove two new F350 SRW V10 gasser Fords. One had 3.55 gears and the other had 4.30 gears. The 3.55 was a dog; the 4.30 was a rocket. I got out pulled by a 4-cyl Camry on I-65 in downtown Birmingham in that 3.55 truck.
Wake Up America
2019 Lance 1062 and 2018 F-350 CC PSD 4X4 DRW
Tembrens, Rear Roadmaster Sway Bar, Torklift 48" Extention and 30K Superhitch
Our New Lance 1062 Truck Camper Unloading at Dealer Photos
jimh425
Western MT
Posted: 03/31/21 07:23pm Link  |  Quote  |  Print  |  Notify Moderator
I don’t but if it has the 10 speed transmission my guess is it would be fine even on mountains if it is rated for enough payload. Ford would probably have no advantage in producing a combination that can’t haul 2500. So, I’d look to see what payload it’s rated for.
billtex
RI
Posted: 04/01/21 04:50am Link  |  Quote  |  Print  |  Notify Moderator
Right, with the ten speed tranny this will be fine. I think I would go for the 3.73, but that’s me.
Will you be towing anything behind the TC?
What is your goal for the 3.55 ratio?
IMO rear end ration has very little effect on mpg. Driving habits will have a greater impact.
2020 F350 CC LB
Eagle Cap 850
25'Airstream Excella
"Good People Drink Good Beer"-Hunter S Thompson
jimh425
Western MT
Posted: 04/01/21 04:55am Link  |  Quote  |  Print  |  Notify Moderator
Just fyi, my 4.30s kill MPG over 65. Yes, 4.30s are pretty high, but still, they have a huge impact even on cruise control. The RPMS are much higher. In case you didn’t notice, I have 6.4 diesel.
Posted: 04/01/21 08:59am Link  |  Quote  |  Print  |  Notify Moderator
Absolutely amazing this is even a point of discussion.
A 5.4 under the hood of a F250 would haul a TC around at highway speeds without significant issue.
Guess it depends what you want your 0-60 and 1/4 mile trap times to be with a camper in the bed...
mkirsch
Rochester, NY
Posted: 04/01/21 11:23am Link  |  Quote  |  Print  |  Notify Moderator
If it were 1978 and all I had was a 3-speed automatic transmission, I would have to say the 3.55 is a bad choice if you want to tow or haul much.
HOWEVER it is not 1978 and the truck comes with at least a 6-speed transmission if not a 10-speed. The numerically lower axle ratios really "punch up" in this day and age due to the fact that there are more available gears to better match the load being towed.
I don't know what the fascination is with being able to roar up every hill in top gear. It does not make sense to me. You're leaving a lot on the table for when you're not towing or hauling.
On a 6-speed, you run in 4th when towing and 5th and 6th are for when you're not towing.
mellow
Salisbury, MD
Posted: 04/01/21 11:24am Link  |  Quote  |  Print  |  Notify Moderator
https://youtu.be/le_CdRGAmvg
Video of the 7.3 with 3.55 gears towing 24K through the Rockies.
2002 F-350 7.3 Lariat 4x4 DRW ZF6
2008 Lance 1191 - 220w of solar - Bring on the sun!
billtex
RI
Posted: 04/02/21 05:49am Link  |  Quote  |  Print  |  Notify Moderator
And six speed tranny?
Page of 5
