RV.Net Open Roads Forum: Beginning RVing: Moisture behind mattress? (Cold caught us)
 > Moisture behind mattress? (Cold caught us)
DavidandDayle
Guelph, Ont
Posted: 04/04/21 09:30pm Link  |  Quote  |  Print  |  Notify Moderator
We found that we were getting water on the walls of cupboards that were along the outer walls. We now put dehunidifier units (chemical things with a bucket -- I forget the brand name) on the floor of the closets. i started by thinking there was a leak.
We had the mattress/sheets freeze to the back wall.
David and Dayle
joelc
Cedar Point, NC
Posted: 04/06/21 10:27am Link  |  Quote  |  Print  |  Notify Moderator
If you are getting water intrusion and you don't have the cabinets exposed to inside air, you might have a roof or leak along a seal. Check all sealant areas.
