RV.Net Open Roads Forum: General RVing Issues: hot water rv heater
 > hot water rv heater
machunt
cincinnati ohio
Posted: 04/01/21 02:43pm Link  |  Print  |  Notify Moderator
Will the hot water heater light on Lp if no water in tank?
corvettekent
Marysville, WA
Posted: 04/01/21 02:54pm Link  |  Print  |  Notify Moderator
Yes, but don't do it.
2007.5 GMC Dually EC/LB, LMM. Banks IQ, Speed Brake, Six Gun. B&W Turnover Ball, Companion Hitch, Amp power steps. Hadley Air horns.
2004 32' Carriage 5th wheel. 860 watts of solar MPPT and four 6 volt batteries. Samlex 2,000 watt Pure Sine Wave Inverter.
Posted: 04/01/21 03:33pm Link  |  Print  |  Notify Moderator
Well why would you want to heat HOT water?
Now to answer your question YES. and that's not a good thing
Same for the electric element it will come on without water.. Till it burns up.
IF your water heater is an ATWOOD or like there is a foam pad with the letters E.C.O. and T-Stat on it. Remove one of the RED wires from the E.C.O. when you drain the tank, Reattach after you refill the water heater...
What does this do.. Prevents you from saying OH CH!!!! I did not fill the tank.. (I've forgotten the wire. and Why the )!Q@#$R did the fault..... oH I forgot the wire.) But I remember to fill the tank when that happens.
spoon059
Just north of D.C.
Posted: 04/01/21 04:57pm Link  |  Print  |  Notify Moderator
Beat me to it. My water heater heats my COLD water.
2015 Ram CTD
2015 Jayco 29QBS
Old-Biscuit
Verde Valley
Posted: 04/01/21 05:04pm Link  |  Print  |  Notify Moderator
YES...either Suburban or Atwood will fire (light off the porpane0 or electric element) if either are turned on W/O water in the WH Tank
If you drain it.....
Open the AC Circuit Breaker for the ELEMENT and remove Spark Electrode For SUBURBAN Model
Pull the 2A fuse on water heater circuit board for ATWOOD Model
*That stops AC & LP from functioning
If you turn on the Electric element W/O water ---it will burn up within a few minutes------have to replace element
If you turn on the LP it will fire and the Tank will get REAL hot REAL quick and the T-stat will OPEN stopping the firing
**If that happens let it cool naturally...do NOT fill with water until cooled down---you will damage the tank/tank lining
Water is only COLD upon initial filling.....reheat occurs when water temp gets to 110*F....that is still considered HOT
So get off the semantics Sheesh.
US NAVY------USS Decatur DDG31
machunt
cincinnati ohio
Posted: 04/01/21 05:30pm Link  |  Print  |  Notify Moderator
i had it in for service and they checked water heater, and said it would not light on lp?
nickthehunter
Southgate, MI
Posted: 04/01/21 06:14pm Link  |  Print  |  Notify Moderator
Mine heats hot water. It comes on when the water temp hits about 120 and goes off when it hits about 140.
BB_TX
McKinney, Texas
Posted: 04/01/21 06:38pm Link  |  Print  |  Notify Moderator
Yep. Only time mine heats cold water is the very first time I turn it on. Each time after that it heats the hot water. So more often than not, it is a hot water heater. [emoticon]
Boon Docker
Posted: 04/01/21 07:00pm Link  |  Print  |  Notify Moderator
Yup. That is what "hot water heaters" are for, to make the hot water hotter.
I thought everyone knew that.[emoticon]
Old-Biscuit
Verde Valley
Posted: 04/01/21 08:42pm Link  |  Print  |  Notify Moderator
THAT^^^^ has nothing to do with whether or not water is in the WH Tank
What Brand/Model is it.....
Had it in for service and they said it wouldn't light on LP
BUT didn't find why/fix why?????
Great service.........horse pucky!!
LP is a simple 12VDC Circuit
Generic....
DC from fused source goes to LP the On/Off Switch
From switch it goes to
*DC Junction box on Suburban---then to the set of DC T-stats----then to circuit board----from circuit board to the gas valve/spark electrode
*DC goes to Circuit Board on Atwood....then to/thru thermals fuse and T-stat back to circuit board. Then goes to/thru ECO (high temp t-stat) and then to gas valve and Spark electrode
So follow the DC....simple
Post Brand/Model for specific info
