RV.Net Open Roads Forum: General RVing Issues: hot water rv heater
 > hot water rv heater
smarty
new mexico
Posted: 04/02/21 10:25am Link  |  Print  |  Notify Moderator
not mentioned thus far is that when you lite your hot water heater after not being used for awhile one should always check the relief valve on the hot water heater to make sure all air is purged. If no water comes out your tank is empty. DO NOT TURN THE HEATER ON. If this is the case.
Old-Biscuit
Verde Valley
Posted: 04/02/21 01:18pm Link  |  Print  |  Notify Moderator
Actually .....NOT the T&P but open a faucet Hotside so air is bleed out of hotside/Water heater fills to correct water level and maintains the AIR POCKET that helps control pressure increases when heating water
Opening the T&P can disrupt the formation of that air pocket
US NAVY------USS Decatur DDG31
Boon Docker
Posted: 04/02/21 01:29pm Link  |  Print  |  Notify Moderator
It is surprising how many people do not realize that.
spoon059
Just north of D.C.
Posted: 04/02/21 02:22pm Link  |  Print  |  Notify Moderator
Old-Biscuit wrote:
Water is only COLD upon initial filling.....reheat occurs when water temp gets to 110*F....that is still considered HOT
So get off the semantics Sheesh.
It heats cold water, it maintains hot water. Didn't know I needed your permission to comment about someone else's post, I'll consider that moving forward.
2015 Ram CTD
2015 Jayco 29QBS
Boon Docker
Posted: 04/02/21 02:28pm Link  |  Print  |  Notify Moderator
This place is so funny at times. [emoticon]
Old-Biscuit
Verde Valley
Posted: 04/02/21 03:18pm Link  |  Print  |  Notify Moderator
MFL
Midwest
Posted: 04/02/21 06:18pm Link  |  Print  |  Notify Moderator
mr_andyj
Georgia
Posted: 04/02/21 06:27pm Link  |  Print  |  Notify Moderator
wa8yxm wrote:
Well why would you want to heat HOT water?
Wow. I sure hope wa8ysm is still not driving too.
Yes, it will light and heat. Some steel tanks are lined with an anti-rust coating and that will be ruined. Aluminum tanks may not be lined, so other than possible warping, I do not know what damage would occur. The propane will be much worse I assume than the electric element as the element is not touching the tank, but the propane flame is.
I accidentally had the electric on all winter, but did not keep camper plugged in too often as solar was on roof, but did have it plugged in plenty long enough to find out... and when I put water in there were no leaks. I t was well after that until I realized the electric was on, when I tried running the AC off a gen and kept tripping the breaker with both AC and tank on.
When gas is on at least it makes noise.
spoon059
Just north of D.C.
Posted: 04/03/21 05:50am Link  |  Print  |  Notify Moderator
Old-Biscuit wrote:
Ha, you mad bro? Didn't mean to make you cry...
pitch
NY
Posted: 04/03/21 06:08am Link  |  Print  |  Notify Moderator
How many of you guys thought that the ever popular, "Why would you heat hot water?" was witty and original?
Betcha you're the life of all the parties!
