RV.Net Open Roads Forum: Fifth-Wheels: Standard hitch vs. gooseneck hitch
 > Standard hitch vs. gooseneck hitch
Michelle.S
Western NY till fall, then Sebring, FL
Posted: 04/09/21 05:28pm Link  |  Quote  |  Print  |  Notify Moderator
The Andersen is a "Ball and Coupler Hitch" and it's Lippert who manufactures a majority of frames for most MFRs that has come out with a memo to MRFs that they will no longer cover Frame failures if an Andersen or real Goose Neck Adapter has been used.
2018 Chevy 3500HD High Country Crew Cab DRW, D/A, 2016 Redwood 39MB, Dual AC, Fireplace, Sleep #Bed, Auto Sat Dish, Stack Washer/Dryer, Auto Level Sys, Disk Brakes, Onan Gen, 17.5" "H" tires, MORryde Pin & IS, Comfort Ride, Dual Awnings, Full Body Paint
cummins2014
Utah
Posted: 04/09/21 05:49pm Link  |  Quote  |  Print  |  Notify Moderator
Well they need excuses for the amount of failures they have , which one do they use when the frame comes apart on a conventional hitch , as said before read many many frame failures , and as far as the ones I’ve read about , they were never blamed on an Andersen.
JIMNLIN
Oklahoma
Posted: 04/10/21 07:51am Link  |  Quote  |  Print  |  Notify Moderator
Yeah...lots of fake news in social media.....and rv websites in general mostly pushed by those that never use the product being discussed or other brand fan boyz, and specifically mfg voiding their trailers frame warranty because a certain brand 5th wheel hitch is used.
PullRite has the same style hitch as a Andersen and nothing was said about its use voiding a rv trailers frame warranty. I would think Lippert would say all brands of Andersen type hitches and not just one brand.
cummins2014
Utah
Posted: 04/10/21 09:40am Link  |  Quote  |  Print  |  Notify Moderator
There has been a long lengthy discussion about this warranty thing with the Andersen over on the Montana Owners Forum. Many on there tow with the Andersen . I have no concerns about the frame on mine, as said this is the second fifth wheel I have used the Andersen .
You are correct the Pullrite is the same exact hitch, with never a mention . Said it along ,most if not all the negative comments come from those that have never towed an inch with the Andersen . Bottom line IMO its the only way to go on towing a fifth wheel, once you have towed with one you will realize that.
Ron3rd
Upland, CA USA
Posted: 04/10/21 05:32pm Link  |  Quote  |  Print  |  Notify Moderator
Great; can you get us all a copy of that memo?
Refer also to the Andersen Multi Million Dollar Warranty posted prior.
2016 6.7 CTD 2500 BIG HORN MEGA CAB
2013 Forest River 3001W Windjammer
Equilizer Hitch
Honda EU2000
Ron3rd
Upland, CA USA
Posted: 04/10/21 05:37pm Link  |  Quote  |  Print  |  Notify Moderator
...not to mention over at the Grand Design forum where lots of Solitude owners (the equivalent of Montana) are going to Andersen. Just pop it out of your bed and put it in the basement of your fiver if you like.
But like anything else, the Andersen is just one choice in a field of many. All of them work.
Michelle.S
Posted: 04/10/21 05:52pm Link  |  Quote  |  Print  |  Notify Moderator
Here is the Keystone Memo:
MEMORANDUM
To: All Keystone Dealers
Date: March 1, 2021
Re: WARRANTY COVERAGE RELATED TO DAMAGE
CAUSED BY GOOSE NECK ADAPTERS
As you all know, Keystone fifth wheels come equipped with a pin box system designed to be used with a
conventional fifth wheel hitch system. Sometimes customers use goose neck adapters with the
conventional systems. Before Keystone would consider covering under its limited warranty any damage
to a fifth wheel caused by or associated with a goose neck adapter, the adapter would need to have
been approved by Keystone. Otherwise, the “unauthorized” attachment, in this case the goose neck
adapter, would cause an exclusion from warranty coverage.
There are various brands of goose neck adapters in the industry, none of which have ever been
“authorized” or “approved for use” by Keystone, except for the Reese Goose Box and the Anderson
Ultimate 5th Wheel Connection Goose Neck Adapter. Over the past couple of years we have noticed an
increase in the number of frame failures and sidewall damage on fifth wheels that use the Anderson
Goose Neck Adapter.
Lippert Components is the leading frame supplier in the RV Industry and has the expertise to evaluate
the use of goose neck adapters and the effect of their use on a fifth wheel. We approached LCI and
were informed that it has not, and it will not, honor or pay any warranty claims for damage to the front
end frame/structure or any parts or components of any fifth wheel, when a fifth wheel is being used
with any goose neck adapter, with the exception of the “Reese Goose Box” (having gone through
extensive suitability testing by Reese and LCI). LCI informed us that this policy and warranty exclusion,
except for the Reese Goose Box, applies to all brand fifth wheels currently being sold the in RV
Industry today, not just Keystone.
In light of the position being taken by LCI with all fifth wheel brands in the industry and Keystone’s
further evaluation of the effects of a goose neck adapter on a fifth wheel, Anderson Goose Neck
Adapters are no longer authorized or approved for use on Keystone, Dutchmen or CrossRoads products.
This decision is not a commentary or negative statement regarding the Anderson brand or the quality of
the brand. And, this does not mean that an Anderson Goose Neck Adapter cannot be used with a
Keystone product. Rather, we are simply stating that if Anderson Adapter is used by a customer with a
Keystone fifth wheel and later damage or loss occurs to the fifth wheel as a result of using the Anderson
Adapter, Keystone will not warrant the same or cover the cost of any such damage or loss.
We want to give you some runway to adjust to our updated policy on Anderson Goose Neck Adapters.
Therefore, should a dealer/customer encounter a failure on any Keystone, Dutchmen or CrossRoads
product which is thought to be affected by the use of the Anderson Ultimate 5th Wheel Connection
Goose Neck Adapters installed prior to March 15, 2021, follow the normal process to receive warranty
consideration for those claims.
Any Anderson Goose Neck Adapters installed after March 15, 2021, will not be eligible for warranty
consideration. Proof of the date of the Anderson installation will be required as part of any claim
submission.
For additional assistance, contact a Customer Service team:
Luxury (LX)
Toy Haulers
(TH)
Premium
(PR)
Light Weight
(LW)
Traditional
(TR)
Dutchmen
(DM)
CrossRoads
(CR)
Alpine Fuzion/Impact Cougar Bullet Hideout Aerolite Cameo
Arcadia Raptor/Carbon Sprinter Outback Residence Aspen Trail Cruiser
Avalanche Rubicon Passport Retreat Atlas Hampton
Laredo Voltage/Endurance Springdale Coleman Redwood
Montana Yukon Summerland Denali Sunset Trail
HC Montana Kodiak Volante
Zinger
tll
NW Wisconsin
Posted: 04/10/21 06:43pm Link  |  Quote  |  Print  |  Notify Moderator
I've been following threads like this as we plan on upgrading to a fifth wheel, and really want to make the best choice for a hitch. The above Keystone letter refers to the "Anderson Goose Neck Adapter". No such thing on their website. They offer the "Ranch Hitch Adapter", which appears to be a goose neck adapter, and the "Anderson Ultimate Hitch" Which is a hitch and not an adapter. So what is the above letter referring to? I just don't yet know enough about fifth wheel hitches.
* This post was edited 04/10/21 07:36pm by tll *
2015 Starcraft 299BHU
2011 Jayco X23J(sold)
2009 Ford F150 FX4 SuperCrew
Thermoguy
Graham, WA
Posted: 04/10/21 07:10pm Link  |  Quote  |  Print  |  Notify Moderator
I've also been following this and many threads on similar adapters. Since I have 2 trailers, a gooseneck and a 5th wheel, it would be nice to not have to remove the B&W Companion when switching to my gooseneck. However, reading reviews on Amazon, seeing the failures, I would not go with Anderson. The other issue is the frame issue. My trailer is older, so no manufacturer is going to warranty the frame in my opinion. So, why take a chance. Even if it doesn't happen, it could and that's too much of a gamble for me. I'll stick with the hitches I have. When I have to tow both trailers back to back, I just lift the B&W base, slide it forward, install my ball, and hook up the gooseneck. If I need the bed of my truck, I remove the hitch, make sure the ball is turned down, and I am good to go. I definitely am a proponent of the B&W due to its sturdy design and ease of hitching.
JIMNLIN
Oklahoma
Posted: 04/11/21 06:25am Link  |  Quote  |  Print  |  Notify Moderator
https://andersenhitches.com/collections/........tch-adapter/products/ranch-hitch-adapter
Big difference in what the memo says and what other members want it to say.
The Andersen type 5th wheel hitch isn't a GN/5th wheel adapter....but Andersens Ranch adapter is.
