Crowe
Merrimack, NH
OK, so the first two responses on my question gooseneck vs. regular pin hitch don't give me warm fuzzies. Sooooo, it's been almost 20 years since we had our fifth wheel. One of our biggest issues was if we wanted to use the pick-up for hauling the hitch was a pain (and heavy!) to get in and out of the bed. Have they been made any more "portable" so-to-speak? Thanks!
I may not have gone where I intended to go, but I think I have ended up where I needed to be Douglas Adams
RV-less for now but our spirits are still on the open road.
Michelle.S
Western NY till fall, then Sebring, FL
GOOD Hitches are by nature Heavy, there are light weight hitches on the market, but you need to do your research because on lot depends on the size and weight of your 5th wheel.
2018 Chevy 3500HD High Country Crew Cab DRW, D/A, 2016 Redwood 39MB, Dual AC, Fireplace, Sleep #Bed, Auto Sat Dish, Stack Washer/Dryer, Auto Level Sys, Disk Brakes, Onan Gen, 17.5" "H" tires, MORryde Pin & IS, Comfort Ride, Dual Awnings, Full Body Paint
MFL
Midwest
So what new truck do you have? Many have the factory installed puck system in HD trucks beginning around 2012. If your truck does not have the puck system, even standard rails are easy to install now in most trucks. IMO, having rails, but removing a standard hitch, leaves the bed useable for most things. Lots of standard hitches are easily/quickly separated into two pieces making them quite manageable by one person.
Jerry
Crowe
Merrimack, NH
MFL wrote: So what new truck do you have? Many have the factory installed puck system in HD trucks beginning around 2012. If your truck does not have the puck system, even standard rails are easy to install now in most trucks. IMO, having rails, but removing a standard hitch, leaves the bed useable for most things. Lots of standard hitches are easily/quickly separated into two pieces making them quite manageable by one person.
Jerry
2021 F350, no hitch or anything as of yet. I can't even remember what our old hitch looked like. One of the reasons why we moved away from the 5th wheel was because of the rail system.
MFL
Midwest
While not standard, I think most 21 F350s would have the fifth wheel prep system (puck system). For your Ford, I suggest best hitch, if FW prep kit, is the B&W 3300. Easy in/out, two pieces 75 lb head, 78 lb base. This a great hitch, very reliable, and user friendly.
Smooth bed, no rails!
Jerry
Cummins12V98
on the road
MFL wrote: While not standard, I think most 21 F350s would have the fifth wheel prep system (puck system). For your Ford, I suggest best hitch, if FW prep kit, is the B&W 3300. Easy in/out, two pieces 75 lb head, 78 lb base. This a great hitch, very reliable, and user friendly.
Jerry
YEA, what Jerry said.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Flashman
Tucson, Aizona, USA
Andersen hitch - 35 pounds. Easy peasy. Over 25000 miles on mine and take in and while camping. Thousands sold and very happy customers.
Crowe
Merrimack, NH
Jerry
Thanks! I'll look into that. I've done some research and one of the biggest cons to a gooseneck is it's less stable towing than a standard pin hitch. That by itself is enough for us to stay with the pin style.
Crowe
Merrimack, NH
Flashman wrote: Andersen hitch - 35 pounds. Easy peasy. Over 25000 miles on mine and take in and while camping. Thousands sold and very happy customers.
Problem is it could void the Lippert frame warranty. Still investigating on that one.
Flashman
Tucson, Aizona, USA
Crowe wrote: Flashman wrote: Andersen hitch - 35 pounds. Easy peasy. Over 25000 miles on mine and take in and while camping. Thousands sold and very happy customers.
It does NOT void the warranty! Quit spreading lies.
