RV.Net Open Roads Forum: Class A Motorhomes: Garage floor coating recommendations
 > Garage floor coating recommendations
rsqfyrmedic
Miami, FL
Posted: 04/03/21 09:23am Link  |  Quote  |  Print  |  Notify Moderator
Howdy all....building a new detached garage for the rig and looking at a product called Armorpoxy. Supposedly has a commercial/military grade topcoat and thicker than the water based epoxy from the big box stores. Looking to protect the new concrete floor and would love to hear from anyone that's tried a garage coating and could share insights. I'll be handling the labor. We have a 39' Diesel pusher that weighs 33k lbs dry so we need something pretty "heavy duty" and won't peel under that weight. Thanks in advance!
PastorCharlie
NC
Posted: 04/03/21 10:41am Link  |  Quote  |  Print  |  Notify Moderator
I had the concrete polished to a glaze when they poured my shop. Doesn't need a top coat if done right during construction.
C20
Shawnee KS
Posted: 04/03/21 08:05pm Link  |  Quote  |  Print  |  Notify Moderator
We did a really nice coating on ours. If I knew how to post a pic on here I would. Pm me for an email address and I’ll send you a pic
2015 Monaco Dynasty
97 jeep wrangler
16 HD CVO Street glide
2015 Challenger Hellcat
2020 ram 2500 Cummins
rgatijnet1
Posted: 04/04/21 05:54am Link  |  Quote  |  Print  |  Notify Moderator
A lot depends on if you use a vapor barrier under the concrete and how long it has been allowed to cure/dry. Coat it too soon and you will have issues. It takes at least 30 days for the concrete to cure and if no vapor barrier is used, there may still be some moisture coming up through the slab. We used to tape a piece of plastic visqueen about 3' square over the slab in a few locations and let it sit for a day or so to check to see if any moisture is still present. If the slab is completely dry than the Armorpoxy coating should work fine.
dodge guy
Bartlett IL
Posted: 04/04/21 06:49am Link  |  Quote  |  Print  |  Notify Moderator
In my attached garage 28X20 I used Rustoleum 2 part Epoxy. It lasts about 10 years before it needs to be recoated. Once dry any epoxy is rock hard and will hold up under the weight of your MH. I needed 2 color kits (4 gal) and 2 clear kits (2gal).
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
RLS7201
Posted: 04/04/21 11:15am Link  |  Quote  |  Print  |  Notify Moderator
X2
My 68 year old garage floor was polished at construction time. Still looks nice and is easy to clean.
Richard
95 Bounder 32H F53
460/528 stroker
Web Master
MWPSchooners.com
First brake job
1941 Hudson
Bruce Brown
Northern NY
Posted: 04/04/21 02:18pm Link  |  Quote  |  Print  |  Notify Moderator
Agreed on the vapor barrier. If you don't have one don't bother coating it, it won't stay down anyway.
Side note, part of my real job was selling concrete coatings.
There are 24 hours in every day - it all depends on how you choose to use them.
Bruce & Jill Brown
2008 Kountry Star Pusher 3910
PastorCharlie
NC
Posted: 04/04/21 04:00pm Link  |  Quote  |  Print  |  Notify Moderator
I've never seen a painted concrete highway or bridge. They hold up pretty well with all the heavy traffic on them. Build them right and they do not need any cosmetics to make them serviceable or look good.
dougrainer
Carrolton, Texas
Posted: 04/05/21 12:33pm Link  |  Quote  |  Print  |  Notify Moderator
My friends and I use Epoxy Coat. BEST STUFF IN THE WORLD. Even Brake fluid will not harm it. Takes 3 to 5 days to get it. Doug
https://epoxy-coat.com/?gclid=CjwKCAjw6q........65jMhQWLVY8WvIegwvNGUeQu7LBoCF5gQAvD_BwE
dodge guy
Bartlett IL
Posted: 04/05/21 01:39pm Link  |  Quote  |  Print  |  Notify Moderator
No, but it looks so much better and is easy to clean when it’s done. It just gives it a much more “appealing look”.
