RV.Net Open Roads Forum: how long of a 12 ga extension cord is safe to use
 > how long of a 12 ga extension cord is safe to use
cac43
mo
Posted: 04/03/21 07:32pm Link  |  Quote  |  Print  |  Notify Moderator
our daughter she would help us when we go visit her with our class C. she installed a singles 30 amp rv plug in at the side other house for us to use. problem is the outlets almost 100 feet
away from where we park. because of power loss from distance, I'm afraid that it will not work from that distance even if we only have fridge and ac running- would turn off ac if need to use microwave. any advice ? thanks. chuck
Ed_Gee
Central Oregon coast
Posted: 04/03/21 08:01pm Link  |  Quote  |  Print  |  Notify Moderator
Without AIr Condx I have often used 2 50' 12Ga extension cords with no problems on my 30A RV. If possible, you might try using 1 50' 12 gage cord to your RV's shore power cord ... which is 10 gage.... if it will reach.
Ed - on the Central Oregon coast
2018 Winnebago Fuse 23A
Scion xA toad
RichB3125
Beavercreek, OH
Posted: 04/03/21 08:08pm Link  |  Quote  |  Print  |  Notify Moderator
Buy three 30A extension cords plus the one on the rv. Then you should not have any problems unless you really overload the system.
Rich
theoldwizard1
SE MI
Posted: 04/03/21 08:12pm Link  |  Quote  |  Print  |  Notify Moderator
I would use a 10 gauge cord AND a Micro Air EZ Start on the AC.
pianotuna
Regina, SK, Canada
Posted: 04/03/21 08:20pm Link  |  Quote  |  Print  |  Notify Moderator
Hi,
You have correctly identified voltage drop as a problem. #10 wire may not be enough to solve this issue.
On 30 amps, it is not advised to run the air conditioner and microwave at the same time.
The best solution may be an autoformer. See my signature for the one I use. If you have a friend who travels to Mexico--they are an off the shelf item.
Regards, Don
JRscooby
Indepmo
Posted: 04/04/21 06:28am Link  |  Quote  |  Print  |  Notify Moderator
When thinking about voltage drop you need to also think about how long is the run from breaker to outlet.
My AC has a 20 AMP plug on the cord. When I want to run AC when not plugged into a 30 Amp, I don't plug in the trailer, I plug in the AC
GrandpaKip
Flat Rock
Posted: 04/04/21 08:17am Link  |  Quote  |  Print  |  Notify Moderator
I have a total 110’ run from breaker to trailer using 10 gauge solid wire and the trailer’s 10 gauge cord set.
There is usually 120-122 volts with small loads and a 4 volt drop with the a/c running. I only tested the a/c once and didn’t see the initial drop as the a/c started. I have no need to run the a/c in the trailer at home as I don’t have any a/c in the house.
I have an EMS, so I really don’t worry too much about voltage drops.
I would not run any less than 30 gauge that far unless you are just going to have a small (10 A or so) load.
Kip
2015 Skyline Dart 214RB
2018 Silverado Double Cab 4x4
Andersen Hitch
time2roll
Posted: 04/04/21 10:09am Link  |  Quote  |  Print  |  Notify Moderator
Before you plug in verify the 30 amp connector is 120 volts fed by a single breaker. Also check polarity. Notorious for being wired wrong.
Get a 100' extension. Check your running voltage the first few days. 108+ is fine. Some dip at start up is ok.
For best power get or make an extension with 30 amp connectors and #10 wire.
675w Solar pictures back up
jdc1
Rescue, Ca
Posted: 04/04/21 10:21am Link  |  Quote  |  Print  |  Notify Moderator
This sounds like a $600 mistake waiting to happen.
CA Traveler
The Western States
Posted: 04/04/21 10:28am Link  |  Quote  |  Print  |  Notify Moderator
STOP DO NOT USE THAT PLUG until you are absolutely sure that it's a correctly wired 120V 30A RV plug. RVers that have plugged into one that was wired for 240V let their smoke out. And that includes ones installed by an electrician. The 30A RV plug is NOT a common household plug and installers make assumptions.
Buy 75' of 30A RV extension cords ($100+ on Amazon) and you will be OK based on your plan. Since the house wiring and voltage is unknown plug in a digital voltmeter and check the RV voltage as you turn on loads.
2014 Grand Cherokee Overland
Bob
