RV.Net Open Roads Forum: Are 16" tires still common? South america.. And disk brakes
 > Are 16" tires still common? South america.. And disk brakes
rerod
Iowa
Posted: 04/08/21 07:21pm Link  |  Quote  |  Print  |  Notify Moderator
JIMNLIN wrote:
The OPs question ??
I didn't see what year model Dodge the OP was using but my '03 was the first year model new designed 3rd gen Dodge truck came with 17" wheels..... larger diameter brakes. My set of OEM size off road tires mounted on 16" OEM wheels on my previous '01 Dodge would not work on the new '03 truck.
It's a 12 valve with 3rd gen wheels..
12 valve ram
CavemanCharlie
Storden,MN
Posted: 04/09/21 09:16am Link  |  Quote  |  Print  |  Notify Moderator
Before you swap out the rims between the trucks make sure the hole size (the part that goes over the hub) in the middle of the rim is the same. It's quite rare that it would be different but, there was one time; back in the day; when we tired to swap rims like that and found it would not work.
And, way ;back in the day; Dodges used to hare reverse lug bolts on one side of the vehicle. Don't twist them off. If the don't come loose easily try turning them the other way.
memtb
Wyoming
Posted: 04/14/21 10:27am Link  |  Quote  |  Print  |  Notify Moderator
Can’t answer the Mexico/tire question!
Disc Brakes are an absolute “Thumbs-Up”! However, be “very” careful with brake gain adjustment. [emoticon] I badly, “flat-spotted” 4 of 6, brand-new, very expensive Continental 17.5” tires! memtb
Todd & Marianne
Miniature Schnauzer's - Sundai, Nellie & Maggie Mae
2007 Dodge Ram 3500, 6.7 Cummins, 6 speed manual, 3.73 ratio, 4x4
2004 Teton Grand Freedom, 39'
2007 Bigfoot 30MH26Sl
rerod
Iowa
Posted: 04/16/21 08:51pm Link  |  Quote  |  Print  |  Notify Moderator
Ive learned a couple things. E350 rims have 1/4" positive offset and 17" tires are hard to find in mexico and the americas..
Reading that airstream are selling their trailers with LT tires on some has turned me into a believer..
I'm stuck trying to decide if I can run a aggressive 16" AT tread on the truck like a KO2, yet run a more trailer like same size LT spare like the rib or R250 if the truck gets a flat..
Posted: 04/17/21 10:35am Link  |  Quote  |  Print  |  Notify Moderator
What does a Ford van rim have to do with this? And your Dodge rims have about a 45mm positive offset so different than the Ford rims.
The mysteries of what you’re trying to figure out here are not understandable.
Oh and 17” LT tires are as common as ever in the US and Canada. Can’t speak for Mexico.
[emoticon]
2017 Heartland Torque T29
rerod
Iowa
Posted: 04/17/21 10:18pm Link  |  Quote  |  Print  |  Notify Moderator
E350 rims fall within Dexter's guidelines of no more than 1/2" positive offset. Meaning I could run eight of them and interchange them, trailer to truck if needed.
Posted: 04/17/21 10:31pm Link  |  Quote  |  Print  |  Notify Moderator
The truck wouldn’t have an issue running those wheels, sticking out more than factory. Especially with the little tires you’ll be using.
Idk if the van wheels have the right center bore diameter.
